how hard is it to swap tranny? have YOU done it?
Old Apr 30, 2004 | 01:41 AM
DEZERTE's Avatar
777** The Anti-rice
Car to share your tranny swapping experiences with me? I'm going to be doing this within the next week and I wanna know what Im getting myself into..
Old Apr 30, 2004 | 01:44 AM
RotaryPower27's Avatar
She's alive
There is a post on this somewhere its either here or on rotaryrevelution. you probably know that so i might not be answering your question. are you going from auto to manual
Old Apr 30, 2004 | 01:46 AM
RRTEC's Avatar
Rotartist
5 to 5 swap..lots of times.. it's very simple.. i can do it in about 45 minutes now.. it's a pitfa if your bolts are rusty but other hten that it's cake work....
Old Apr 30, 2004 | 09:02 AM
SOIA's Avatar
Take A Look Around
Did it once and it took bout 2 1/2 hours nothin too complicated gotta remove exhaust and driveshaft, unbolt from engine, unbolt crossmember vola!
Only time consumer was rusty driveshaft bolt, oh and lining up the input shaft on replacement.
edit: be sure to disconnect battery first, theres some live wires
Old Apr 30, 2004 | 09:20 AM
ForsakenRX7's Avatar
zoom zoom go boom
Its nothing major. Taking all bolts out is the hardest part. Make sure you have a friend there to torture buy helping you put up and bring the tranny down. Our hardest part was getting the new tranny to slide back up all the way to the motor.
Old Apr 30, 2004 | 11:00 AM
DelSlow's Avatar
Hot Dicken's Cider
its much easier to have a friend help you hoist it back in, but that was a T2 tranney, NA's are lighter, so you might be able to do it yourself. you also might need someone to move the main pulley back and forth a little while you push the tranney on the eshaft to line up the splines.
Old Apr 30, 2004 | 11:48 AM
Thaniel's Avatar
the 2 things I'd add are:
Tip the motor so the back points down (with the weight of the trans gone it tends to tip forward making installing the trans harder)
Put the trans in gear when reinstalling so you can rotate it to light up the splines in the clutch.
Old Apr 30, 2004 | 11:57 AM
zeus.11's Avatar
Newbie
kwel sounds like its not too hard.. my transmission took a **** last night so i will be doing this job in a few days.,.. hopefully it goes well
Old Apr 30, 2004 | 03:44 PM
lacycw's Avatar
Here's a little more advice... If you still have the intake manifold on which you probably do, it will be much easier if you have long socket extensions with 1 or 2 good universal joints. This way you will be able to take the hard to reach engine to tranny bolts off from under the car easier.
- Cooper Lacy
Azevedo
26
Mar 1, 2019 09:19 PM
sleepydogz
Old School and Other Rotary
Oct 4, 2015 03:46 PM
Snook
180
Sep 6, 2015 12:50 PM
