Can I use this turbo ?????
Old Apr 29, 2004 | 11:36 PM
beaumondt's Avatar
I am looking to get this turbo to use on my stock port
gen 3 .
garrett
Flow rating 500 hp/370kW
Compressor cover 0.7, 4 inch inlet
Compressor Wheel Super V-trim, 6 blade
Exhaust Housing 1.OO
T4 bolt pattern
Split pulse
Turbine High Flow P-trim
Left hand thread shaft
Seal Carbon seal
(suitable for carby setup)
Bearing 360 degree bolt in thrust brg.
(capable of 25+psi)
Can anyone tell me how it will work. I can get this at
quite a reasonable price, and im hopping to put together
a single kit . I already have a manifold.
its only for street use and i would like a useable power band so any input would be appreciated.
Thanks
Terry
Old Apr 29, 2004 | 11:45 PM
MrBob 86's Avatar
MMR bitch
The Compressor wheel is too small to make it worth your effort. You could buy that turbo and upgrade the compressor if you can get it for a good price.
Old Apr 29, 2004 | 11:50 PM
beaumondt's Avatar
Thanks MR bob
What size would you suggest ????
Terry
Old Apr 30, 2004 | 12:11 AM
MrBob 86's Avatar
MMR bitch
How much power are you looking for? What kind of modifications are you prepared to do? For a street car its hard to beat a 60-1. It can get you around 375hp to the wheels, easily.
Check out this thread.
http://www.nopistons.com/forums/inde...howtopic=40259
Old Apr 30, 2004 | 12:53 AM
beaumondt's Avatar
I would like to keep to bolt on mods only for the moment. So what ever the limits of a stock healthy engine are is where i want to be.
What are the exact specs of a 60-1 so i can get an idea of what i should be looking for ?
Terry
Old Apr 30, 2004 | 10:56 AM
MrBob 86's Avatar
MMR bitch
http://store.yahoo.com/cheapturbo/gart0t4w70tu.html
You could buy the turbo you were asking about in your first post and upgrade it with a 60-1 compressor. Any single turbo is going to require a standalone of somekind.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
