13b oil pan
Old Apr 24, 2004 | 07:18 PM
yellowmazdaman's Avatar
13b oil pan
Hey I was looking for an oil pan so I can put my 1989 13b Turbo II into my 1982 GSL RX-7. I know I need a different oil pan to allow the motor to cross the crossmember. But what years can I use? I found a 1986 Mazda RX-7 with a 13B non-turbo rotary engine and I was thinkling I could use that.Will it work??
Old Apr 24, 2004 | 08:31 PM
mwatson184's Avatar
holley guy
you need to use a gsl-se front cover or a front cover from a 12a (first gens motor mounts are on the front cover), and you must use the gsl-se oil pan. IF you use the 12a front cover you have to either buy motor mount adpaters or fabricate them by slotting the holes on the mounts.
Marques
Old Apr 24, 2004 | 10:15 PM
rhinor61's Avatar
12a front cover will work with 12a oil metering pumps (2 tube) and 13b front cover will work with 13b oil metering pump (gsl-se is 4 tube).
John
Old Apr 24, 2004 | 10:35 PM
cosmicbang's Avatar
Older 13b metering pump is 2 tube also. I have successfully modified 13b oil pans before, although not from a FC. If you have an extra you could try it.
Old Apr 24, 2004 | 11:39 PM
jorx81@aol.com's Avatar
Still Dreams of 3rd Gen
if carbing a 6 port will 12a omp be enough for 13b?
Old Apr 25, 2004 | 09:29 AM
mwatson184's Avatar
holley guy
Yes it will be fine.
FD7KiD
15
Feb 26, 2021 10:12 PM
rocker1337
16
Sep 6, 2015 11:28 PM
FD7KiD
Aug 17, 2015 11:50 PM
