is JB-Weld gasoline proof/safe?
Old Nov 1, 2001 | 10:47 AM
tesla042's Avatar
eh?
Old Nov 1, 2001 | 03:12 PM
skibum9199's Avatar
college student
It doesnt say on the package? You arent by chance using it to fill in the holes left from your 6 ports are you? I was thinking that i i could melt some aluminum and pour that in, then grind it smooth wiht the inside of the runner, what do u think?
~Jesse
Old Nov 1, 2001 | 03:47 PM
Jeff20B's Avatar
Lapping = Fapping
JB weld will warp and start to peel away from a surface if exposed to gas fumes for several years. I don't know what will happen to it if immersed in gas.
Old Nov 1, 2001 | 04:09 PM
tesla042's Avatar
~Jesse
Nope...actually, I was going to use it to seal off my pulsation dampner. Before everyone tells me not to: I cut the dampner off, and am left with essentially a banjo bolt--with a hole in the end I figured I could plug. I guess I'll just weld it if i can't find a replacement.
mm...as for the 6p things, I'm not gonna tear down the engine this go-around.. I think pouring aluminum in would probably work, but you should be REAL careful to make sure it bonds with the housing. You don't want it to come off! I like Blake's idea of using a teflon dowel.
-Tesla
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
Cameron38
1st Gen General Discussion
Sep 2, 2015 08:10 PM
