deck install?
Old Apr 13, 2004 | 01:53 PM
Richard Miller's Avatar
Damn, it did start!
deck install?
could someone give me some pointers on installing a cd deck. I know wireing, that is easy, I dont see how it is supposed to secure in the dash.
Old Apr 13, 2004 | 01:57 PM
Todd Staples's Avatar
"A Piece of Work"
installing deck
Best Buy sells a conversion kit and factory plug adaptors all for about $20. It is pretty simple after that. I did have to run new speaker wires top the rear speakers, for some reason could not get tied into them from the factory plugs.
Hope this helps.
Todd
Old Apr 13, 2004 | 02:48 PM
red13brx7's Avatar
It secures into the dash where the exsisting stereo was, you can put a screw through the mounting plate and into the cd player that will hold it in there.. ANd you can custom make something to go around it, or buy something, your choice. The wiring is simple. But watch out for all those 12V constants in there, you will only need one, I think there are 3 when you take everything out... Or something like that.. atleast on mine there is. THis is for an 84-85
Old Apr 13, 2004 | 03:03 PM
anthrax's Avatar
Heck Yes!
The CD player will mount in the OE 2 piece bracket no problem, but like red13brx7 said this is for '84,'84.
I just disconnected the Factory stereo and removed the tape deck and put the CD Player inbetween the radio and amp. When my CD palyer face plate filps around it looks like a knock out plate...
Old Apr 13, 2004 | 03:37 PM
85rotarypower's Avatar
love the braaaap
The next problem you run into though is wiring the speakers. The stock radio has an external amp. You cannot use this with your aftermarket radio. You have to re-wire the speakers also.
Old Apr 13, 2004 | 03:49 PM
anthrax's Avatar
Heck Yes!
Just do what I did, leave the original wires and amps in place and run new wire to the speakers
Easy as pie
Old Apr 13, 2004 | 04:23 PM
mzda_rx7's Avatar
I PWN U
buy it from best buy and let them do the work...j/p
Old Apr 13, 2004 | 04:52 PM
Damn, it did start!
as I said I know wiring. I am not sure about the mounting. you guys gave me some ideas
thanks
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
