AutoZone fuel pump
Old Apr 13, 2004 | 01:35 PM
RotaryRyan's Avatar
DSM
Question AutoZone fuel pump
Has anyone ever bought the universal fuel pump at auto zone that pumps like 2-5psi(The autozone down here sell them anyway). I just wanted to know if it was good or crap. i think its made by master.
Thanks, Ryan
Old Apr 13, 2004 | 01:38 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
You should have a 7 psi pump or better for the Sterling Carb.
Old Apr 13, 2004 | 01:40 PM
bigb3433's Avatar
i just bought one at o'rielys its a purolater/facet puts out 4-7 hope it works for my weber
Old Apr 13, 2004 | 03:06 PM
Jeff20B's Avatar
Lapping = Fapping
I've got Facets on my vehicles. So far, two out of three tend to be inadequite. The other hasn't really been driven hard yet. I'm going to parallel two Facets on one and replace another with a big Carter. I'm not sure what to do about the last one since there is not very much room to mount a big pump.
Old Apr 13, 2004 | 04:00 PM
I'm probably going to send my carb to you just for a rebuild. I'm also going to install a new fuel pump. What is the requirement for a stock nikki?
Old Apr 13, 2004 | 04:07 PM
Lotus00's Avatar
i think it was 3.7 to 4.7 PSI
Old Apr 13, 2004 | 05:51 PM
Rx7carl's Avatar
Airflow is my life
Re: AutoZone fuel pump
Thanks, Ryan
I bought their 7-9 psi one (looks the same, just higher output and pressure) and used a regulator. Its ok for a daily driver.
Old Apr 13, 2004 | 10:50 PM
RotaryRyan's Avatar
DSM
alright cool. thanks carl.
You said it was "ok" for a daily driver. would i get better results with a better pump?
Old Apr 14, 2004 | 07:49 AM
Rx7carl's Avatar
Airflow is my life
It will probably starve a race motor/modded carb/ported engine. Its a small pump and the output isint there for serious hi rpm performance, thats all. For average street driving its fine.
Old Apr 14, 2004 | 09:03 AM
Second2none's Avatar
whats a good carter pump ? need model number so i can go order one
suppose i should add its a 12a turbo, soon to be modded nikki, and eventually a streetport.
Old Apr 14, 2004 | 10:21 AM
RotaryRyan's Avatar
DSM
Well carl, Im getting a sterling carb from yall..... I will probabely need a better fuel pump then. I only have like 50-70 bucks.
Old Apr 14, 2004 | 09:17 PM
prefix's Avatar
You should just spend the extra 20$ and get a holley red pump. You can't beat the 97gph at 7psi. If you can starve an engine that has a holley red feeding it, you deserve a medal.
Old Apr 15, 2004 | 03:23 AM
Jeff20B's Avatar
Lapping = Fapping
I got two of this pump. It's probably more than you'll need. There is a smaller one but i don't have the link for it. http://store.summitracing.com/partde...=CRT%2DP4600HP
Old Apr 18, 2004 | 07:55 PM
Xavier8's Avatar
Never satisfied
I have one of these pumps, and on the guage on the holley regulator the pressure drops slightly when revved at high rpm. Does that mean it is probably inadequate? Its just one of thos cheap autozone type pumps, but I was considering gettting on of the carter fuel pumps.
Rotospectre
Mar 28, 2018 03:33 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
