rat's nest
Old Apr 11, 2004 | 08:00 PM
WuRx7's Avatar
Newbie
rat's nest
removed my rat's nest from my 1980 today. Didn't use the tutorial. I just looked at the diagram under the hood and removed it that way. Ran new vacuum hose where needed. I still have my AC so took care of that too.
That rat's nest was a HORRIBLE design.
Probably the best overall mod for my car to date. I noticed a definate improvement.
Old Apr 11, 2004 | 08:01 PM
I posted this. For whatever reason, I got logged in as someone else.
Old Apr 11, 2004 | 10:35 PM
thricerx7's Avatar
Akina's Ghost
you took out your a/c? did you also remove the condenser in front of the radiator? i attempted to but didn't have the right tools. i was so disappointed. i have been meaning to get rid of it for quite some time now. also when i pass smog, my rat's nest is going bye bye
Old Apr 11, 2004 | 10:38 PM
Fuel524's Avatar
hey how easy was it i was going to do that but i tried buying the tutorial but it never came. maybe you could give some detail. with some pics would be great.
Old Apr 11, 2004 | 10:43 PM
thricerx7's Avatar
Akina's Ghost
isnt there a tutorial on www.mazspeed.com? let me see if i can find it for you fuel524
Old Apr 11, 2004 | 10:45 PM
thricerx7's Avatar
Akina's Ghost
found it bud, here you go.
http://maz_tutorials.ten15.net/
Old Apr 11, 2004 | 10:46 PM
thricerx7's Avatar
Akina's Ghost
YOU GOTTA HAVE ADOBE ACROBAT THOUGH OF COURSE.
Old Apr 11, 2004 | 10:49 PM
thricerx7's Avatar
Akina's Ghost
or here...
http://tom.pratchios.net/Rx-7/tutorial_FC1.pdf.zip
i also want to do it i am trying to find any tutorial just in case one is better than the other. you dig?
Old Apr 11, 2004 | 10:52 PM
thricerx7's Avatar
Akina's Ghost
apparently that link doesnt work. sorry.
Old Apr 11, 2004 | 10:55 PM
Fuel524's Avatar
cool thanx that is cool of you yeah i dont have acrobat that is the same site i tried b4 and no luck. is the pratchios.net one right cuz it says no good???
Old Apr 11, 2004 | 11:08 PM
thricerx7's Avatar
Akina's Ghost
no i guess the second one doesn't work. i am still trying to find a write up... ill let u know if i do...
Old Apr 12, 2004 | 06:25 AM
Actually, I kept my AC. I converted it over to 134a while I was at it. I just took off the AC SV from the rat's nest and hook it up.
Old Apr 12, 2004 | 06:34 AM
Well, this is how I did it. I looked at the diagram for the rat's nest (Haynes or look under the hood of the car). I saw where everything went and ran new lines to the parts that needed to stay (crankcase vent, vacuum advance etc) and plugged the rest. I used three T fittings that were 3/16th and 1 that was 5/16th. I then used either two or three vacuum plugs. The tutorial shows only needing two 3/16th but I used an additional one to get my AC SV working and also running a line to my crankcase vent and purge valve.
Since mine is a 1980, it will differ slightly from yours probably but it should be pretty close.
My blockoff plates were purchased through Mazdatrix and had already been installed.
Old Apr 12, 2004 | 08:39 AM
Rx7carl's Avatar
Airflow is my life
You bought it and you never got it? That is easily fixed, but you need acrobat to read it. Its a free download.
Old Apr 12, 2004 | 08:42 AM
comeonstart's Avatar
I paid for the tutorial on that site where you had to give a donations to get a tutorila but i cant get it
Old Apr 12, 2004 | 09:59 AM
Rx7carl's Avatar
Airflow is my life
Ugh, Email pratch. Im PM'ing you his addy. Sorry for the inconvenience.
ls1swap
Jun 3, 2024 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
Jetlag
Sep 29, 2015 06:52 AM
