Turning steering wheel while stopped lowers idle?!?
Old Oct 30, 2001 | 05:14 PM
Ryde _Or_Die's Avatar
Ok my idle is way high, like 2000+. I know my power steering belt is too tight but haven't gotten around to losening it. I was completely stopped & turned the wheel & noticed the RPMs dropped. So I started turning it back& forth & I made it go down to like 1500 or so from above 2000. Could the tight belt change my idle? Thanks alot. I will prolly find out if that was it before someone responds but never heard of this so was wondering.
Old Oct 30, 2001 | 05:48 PM
tesla042's Avatar
Re: Turning steering wheel while stopped lowers idle?!?
It's not the tight belt.. You have power steering, and by turning the wheel, it causes a little drain on the engine to power the pump. This drain is what's causing your idle to drop. There's something like the BAC, but specific to power steering that is supposed to try to compensate for it, but your idle is so high that I don't think it would even try to operate under those conditions.
-Tesla
Old Oct 30, 2001 | 05:55 PM
HWO's Avatar
HWO
inteligent extratarestril
it's the added load applied to the e'shaft that is used to turn the power steering pump which works harder when you turn the wheels.
Old Oct 30, 2001 | 06:06 PM
Ight, well any ideas on howto lower my idle guys? I want it at like 1000 and I will be happy. Thanks.
Old Oct 30, 2001 | 06:11 PM
AE Turbo's Avatar
Speed from skill
Does turning the idle adjustment screw help any?
Old Oct 30, 2001 | 06:17 PM
I'll know as soon as I know where it is & what to do with it exactly, lol. So where is it? O ya, AE Turbo...see brooke on weakest link last night?
Old Oct 30, 2001 | 06:37 PM
AE Turbo's Avatar
Speed from skill
Yeah, I was screaming at the TV when they voted her off. Ooh she's so foine though.
Old Oct 30, 2001 | 07:02 PM
ItsNiceToBurnRice's Avatar
HEY BRO
Im gonna say its because its drainin a little bit of your power also, because your alternator runs its fullest at high RPM's.
Old Dec 24, 2001 | 07:52 PM
It's a sensor called the power steering sensor. It's attached to the power steering pump. It senses when the wheel is turned (at idle) and increases the RPM's to compensate for the drag the power steering puts on the engine. You can test it by disconnecting the connector and measuring the continuity (with the engine running) while you turn the steering wheel. Mines shot too. Doesn't seem to affect anything else other than Idle RPM.
Old Dec 24, 2001 | 09:09 PM
Erik's Avatar
Best of both worlds
wait...do you mean Brooke Burke? or am i not even close...
if so she is unbelievable...
Old Dec 24, 2001 | 10:58 PM
VashtheStampede's Avatar
if your TPS is out of adjustment,
the computer wont think you're at idle,
so if that power steering sensor only does things at idle.......
anyway.. TPS check and sdjust is here: http://k2rd.freeservers.com/FC3S/TPS/tps.html
the throttle stop screw is right next to the TPS sensor, but on the firewall side of the throttle body. you need to loosen the hex nut (like 8 or 7mm i think) before you can adjust it with a screwdriver.
you also have to adjust your TPS after doing this.
if your throttle plates wont close as you adjust the screw, check to make sure your throttle cables (including the cruise cable) arent hung up somewhere. you can also make an adjustment where the throttle cable mounts to the TB, but i dont think you are supposed to do it that way.
Old Dec 25, 2001 | 07:16 AM
HAILERS's Avatar
HAILERS
EDIT: error. error.
Old Dec 26, 2001 | 01:52 AM
Felix Wankel's Avatar
Super Newbie
Just in case, the idle adjustment is the only screw on the very top of the intake manifold (where it says 13B Injection). I'ts supposed to be under a black rubber cap.
