Power FC how far off is your pfc from your boost gauge?
Old Apr 6, 2004 | 08:06 PM
spoolin93r1's Avatar
I did a little converting on my boost figures from my power fc. it said i was hitting 19.3psi when my boost gauge was showing 16psi, with a slight spike to 17. i've got a gm 3bar. i seriously don't think i could hit 19psi on pump gas without having issues so far. my boost gauge is a defi d series
Old Apr 6, 2004 | 09:08 PM
rynberg's Avatar
The PFC Commander does not display boost correctly, however, that is a very large discrepancy and usually the PFC reads LESS than the boost gauge.
Where is your boost gauge T-ed into and what adjustments have you made to the PFC for the 3-bar sensor?
Also, if you don't have the data-logit, you can do a ghost trace and see what cells the PFC is actually in when it's reading 19 psi.
Old Apr 6, 2004 | 09:11 PM
the boost gauge is running right off of my uim at the extra port like most people i know.
jason at the rx7store did the 3bar install and tune. he set it to option 3.
i just did the peak hold and was kinda glancin at it and at my boost gauge while doing a hard 3rd gear pull. it did it around 8k where my boost gauge had showed a slight spike
Old Apr 6, 2004 | 09:13 PM
reza's Avatar
http://www.onlineconversion.com/pressure.htm
Do you use the kg/cm2 to psi conversion?
Old Apr 6, 2004 | 09:17 PM
no, my friend told me that 760mmHg is equivalent to 1 atm, which would be 14.5psi. i just did the math with a calculator to figure it out
Old Apr 6, 2004 | 10:07 PM
paximus's Avatar
20B FD|20B Cosmo|S5 TII
remember altitude also has something to do with it. here's my conversion calculations for my altitude;
absolute(psi) 8.0 9.0 10.0 10.5 11.0 11.5 12.0 13.0 14.0 15.0
pfc( kg/cm2) .54 .61 .68 .72 .75 .78 .82 .88 .95
gauge/manifold(psi) 10.3 11.3 12.3 12.8 13.3 13.8 14.3 15.3 16.3
so its kind of impossible to match them up, but imagine those are in columns. 8.0 absolute=.54 pfc=10.3psi on the gauge.
pretty crazy huh? my avc-r reads the same as my gauge, just in .bar.
imagine my suprise the first time i hooked up a boost gauge and saw over 12psi the first time i hit the gas!!!
Old Apr 6, 2004 | 10:09 PM
spyfish007's Avatar
Yellow Dragon is no more
I have said this before but I think the UIM extra nipple is the worst point to T from. Insert the T where the MAP sensor reads so you can know what your ECU is doing and so you can get a more stable boost reading. I remember seeing the change on Rich's car with his Profec reading there and then moving it. His boost would oscillate till we moved it-after the move rock steady.
Old Apr 7, 2004 | 02:39 AM
rynberg's Avatar
Yep, the map sensor for my Defi boost gauge is T-ed off of the MAP sensor hose and not the UIM nipple (boost controller is connected there). The PFC Commander still reads a little less than the gauge though, but I think that's good advice.
Old Apr 7, 2004 | 03:08 AM
i might have to try that and see how it works out
Old Apr 7, 2004 | 08:43 AM
pp13bnos's Avatar
Pineapple Racer
Thanks for repeating this....I guess you still learn something new everyday. CJ
BTW, my boost gauge is terriably inaccurate. When I thought I was running 13lbs on the non-seq twins, I was realy running 11! This was backed up by a dyno session with Ralph Friend. I just use it for a reference.
rgordon1979
40
Mar 15, 2022 12:04 PM
AXA
Sep 5, 2015 10:06 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
gabescanlon
Sep 5, 2015 12:09 AM
