Getting rims for my FD
Old Apr 6, 2004 | 06:05 AM
vti-johan's Avatar
Newbie
Hi there!
My first post at this forum:
Im a swedish FD owner and I´ve been looking for rims for my baby for a while now. The problem is that there isn´t that many wheels for the FD over here. Though I´ve managed to find copy´s of BBS RS-GT with the width 8,5" and 9,5". The offset of these wheels are 40.
So my thought was 8,5" in front with 235/40/18 and 9,5" back with 255/35/18 or something like that. Will this fit? I´ve been searching the forum for a while and it seems like the correct offset for 8,5" in front would be like 37!?
My ride isn´t lowered...everything stock.
Thanks
Johan
Old Apr 6, 2004 | 07:46 AM
jeff_yeh's Avatar
Hi there
I have just got some 18" wheels onto my car this week with offset 45 front and back so i dont think the offset will be any problem, however, the front tyres came with the wheels were 235/40/18 and they rub the plastic liner. so today went to pick up some Eagle F1 225/35/18 and now no problem at all!!!
I do wonder if any brand makes 245/35/18 cos it will have the closest diameter to the stock 16" setup....
hope this helps a bit
Jeffrey
Old Apr 6, 2004 | 08:02 AM
AntiVenom7's Avatar
Wouldn't Go If U Paid Me
255/35 is also pretty damned closed too; just a little bit bigger and are a very common size. that is what alot of members have done with a 43-45mm offset on 18x8.5s. That is what I will be running on my car in the front. someone else chime in if I am wrong
Old Apr 6, 2004 | 10:02 AM
rynberg's Avatar
18x8.5 and 9.5 +40 offset will fit just fine. Ideal tire sizes would be 235/40 and 265/35.
235/40 should work no problem, especially with a 45 offset. This is what I'm running and my car is LOW -- 25" to fender. 225/35 is way too short. I would look into other problems with your suspension.
255/35 is too big for an 8.5 wheel, stick with 235/40 or 245/35 -- Pirelli and a few other companies make this size
Old Apr 6, 2004 | 10:55 AM
vti-johan's Avatar
Newbie
Thanks you guys for the help!
I know someone who will order some wheels tomorrow
Old Apr 6, 2004 | 02:53 PM
AntiVenom7's Avatar
8.5 is on the lowest end of what you can fit a 255 on. since i know that we all know how to read tire sizes. we know that the difference in width between a 245 and a 255 is 1cm, which is a little less than 4/10ths of an inch. it would affect your section width by about 2/10s of an inch and would bulge just a little. some people like the wheel to be flush with the tire, but a little bulge will keep the curb rash away.
ideally, you are right, you should run a 9" rim, that is what the tire manafacturer refers to as "measured rim width" but that doesn't mean that a slightly narrower rim can't be run. that is why the give ranges as well as measured rim width when you buy tires.
if i'm wrong i will find out once i get them on my car.
i took the chance since 245/35 limits you to about a half dozen tires. 235/35 are virtually nonexistent and a 235/40 adds almost an inch to the diameter.
Old Apr 6, 2004 | 03:30 PM
rynberg's Avatar
No, 235/40 only adds about .4 to .5" to the diameter. I run that size (along with 265/35 -- same diameter) and have no issues, despite my very low suspension. If nothing else, having a slightly taller wheel/tire raises the ground clearance a little bit in front, which is always helpful in California -- land of the steep-*** driveways.
Old Apr 6, 2004 | 06:17 PM
AntiVenom7's Avatar
your right, my math skills are off today.
it is .543" to be exact.
Old Apr 6, 2004 | 06:30 PM
SpeedKing's Avatar
Power Trippin'
http://www.miata.net/garage/tirecalc.html
Old Apr 6, 2004 | 06:34 PM
AntiVenom7's Avatar
damn that is easier than pushing these #s through a calculator. converting back and forth, etc.
that has officially been added to my favorites.
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
