emissions! what do i do?
Old Apr 5, 2004 | 01:17 AM
rxseven07's Avatar
Registered pimp
yeah i live in nashville tn, and there is no way im going to pass emissions, is there a way (other than paying off the guy) to pass? any tricks, i went in and they guy tried to move the pipe around in my tail pipe and it still didnt pass, the limit is like 200 hydro carbons, and im at 950!!! right now i have a gsl-se with a weber carb on it. what can i do?? thanks guys.
Old Apr 5, 2004 | 01:33 AM
shm21284's Avatar
Fabrineer
HAHAHA our rotaries will pass emissions when Russia wins the cold war
Old Apr 5, 2004 | 01:40 AM
RotaryRyan's Avatar
DSM
maybe run 10-15% alcohol. lean the carb. ive heard of peple doing that, i have no experience with it. if you have an airpump, make sure it works. get a cat converter if you dont have one.
Old Apr 5, 2004 | 01:51 AM
hornbm's Avatar
FD > FB > FC
Re: emissions! what do i do?
Are you still running a cat? Probably not. Heres what I would do. Its a little spendy tho, but I'm sure it'll get those numbers down. Mazdatrix sells a catalytic convertor that takes the place of teh presilencer in the RB exhaust system. I'd get that, and just hook up the air pump (reconnect it) to the air injection line without the ACV. I'm not sure on that part tho. Your car will probably run like **** at cruise however. But Its a temp solution that I think would get you to pass.
Old Apr 5, 2004 | 02:11 AM
rxseven07's Avatar
Registered pimp
yeah i have all my cats on. no air pump. not even available. heres what i was thinking.. bring in a honda civic or something, give the guy my vin number and 50$, stick the sniffer in the civic, but have the info on my car. would that work?
Old Apr 5, 2004 | 02:19 AM
shm21284's Avatar
Fabrineer
apparently in texas (dont knwo about tennesee), they avtively monitor the emissions testing. They may or may not be monitoring your car at the time of the test. The problem is, it will sniff super clean for an rx7 when its really a civic... its worth a shot though. probably the chances of being caught are slim, but the mechanic could get big fines if he is.
Old Apr 5, 2004 | 08:58 AM
riofrio's Avatar
This IS a tasty burger!
rxseven07,
dude, i just had the exact same problem last week (i'm also in nashville) my HC level was like 850. You think you might be running a bit rich? .... i think thats at least one of my problems.
Where in Nashville are you at?
edit: isn't there some kind of a product you can buy at walmart that 'guarantees' to pass emissions, or something?
Old Apr 5, 2004 | 09:33 AM
YapaKanichi's Avatar
Smile Like a Donut
yea then file a lawsuit against em when you fail lol. money money money. I love Florida. My boss tried to play a trick and said cops were looking for catalyic converters on cars. Didn't work with me I know better.
Old Apr 5, 2004 | 12:20 PM
slashdawg00110's Avatar
RTFFAQ
If you have the cats, but you're not running the air pump, you probably have cats that are not functioning. Replace the cats, verify that the air pump is pumping and the ACV is working, and you'll have a much better chance of passing the emissions tests.
Old Apr 5, 2004 | 01:35 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
Old Apr 5, 2004 | 07:39 PM
rxseven07's Avatar
Registered pimp
well i guess there is no true solution. im in the brentwood area, off of nolensville road. i have a tan gslse. u might have seen it around. theres no way i can get new cats, just for the reason that im saving up for a new exhaust, racing beat. it would be pointless to get new cats. ill figure out something. where u located at?
Old Apr 6, 2004 | 08:56 AM
riofrio's Avatar
i'm in the music row area... so pretty much downtown. i don't think i have seen your SE... in fact, i have only seen one FB around, it's black... well, that and my white SE. maybe we can work on 'em together sometime this summer. good luck with the emissions thing... let me know what happens cause i'm going through the same thing.
Old Apr 6, 2004 | 06:20 PM
rxseven07's Avatar
Registered pimp
hey man let me get your name and number. im Richie. 474 5354, whenever u want to work on them hit me up!
ls1swap
Jun 3, 2024 03:25 PM
Snook
Feb 27, 2021 02:54 PM
PinkRacer
43
Oct 1, 2015 09:13 AM
RedBaronII
Sep 20, 2015 11:29 AM
