Squealing!
Old Mar 30, 2004 | 07:23 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
Squealing!
My belt is squealing after about 4k rpm. It is brand new and of quality. However the air pump was recently removed which might be the cause for it. Any remedies for this, other than putting the air pump back on?
Old Mar 30, 2004 | 07:24 PM
V8kilr's Avatar
Dual belt pulley setup
Old Mar 30, 2004 | 07:30 PM
mazdaverx713b's Avatar
Have RX-7, will restore
is it properly tightened? if it is too loose, it will slip and squeal.
Old Mar 30, 2004 | 08:22 PM
cdrad51's Avatar
oh! of course. Ok. I think I'll do that. Thanks.
Old Mar 30, 2004 | 08:23 PM
cdrad51's Avatar
Tighter than a nun's ***
Old Mar 30, 2004 | 08:44 PM
kettlman's Avatar
THE ONE. THE ONLY!
well if its like that one nun that one time in the chappel, you might want to loosen it a tad bit. if its too tight you might be puttin too much strain on your pully's
Old Mar 30, 2004 | 08:48 PM
cdrad51's Avatar
would it squeal after 4k rpm if it's too tight though?
Old Mar 30, 2004 | 09:04 PM
RotaryRyan's Avatar
DSM
you could try belt dressing until you get a duel alt pulley. someone was saying not to use it. i dont know why.
Old Mar 30, 2004 | 09:05 PM
cdrad51's Avatar
belt dressing? sorry, noob here
Old Mar 30, 2004 | 09:40 PM
do not use belt dressing!!!!!!!! that stuff is total crap!!!!!!!!!!!!!!!!!!!!! consider it and it will ruin your belt! fu** that stuff!
Old Mar 30, 2004 | 10:43 PM
RotaryRyan's Avatar
DSM
yeah i knew somethin waas wrong with it. i just figured if he had to pick up his lady or something he wouldnt want it to squeak.lol
Old Mar 30, 2004 | 10:49 PM
cdrad51's Avatar
the lady or the car?
Old Mar 31, 2004 | 06:04 AM
MosesX605's Avatar
My wife bought me 2 RX-7s
Don't bother with the dual pulley setup, just get the fabled 'Yoohoo' belt. Go to NAPA and ask for a 3L220 belt, it's a short little guy and will fit perfect going from your main pulley to the water pump.
I've had mine on for several thousand miles with NO squealing whatsoever.
Old Mar 31, 2004 | 06:10 AM
RotaryRyan's Avatar
DSM
i was talkin about a lady. you dont want to drive your women around in a squeaky car.
Old Mar 31, 2004 | 07:10 AM
THC's Avatar
THC
Gents,
I have had the same problem!!
The Racing Beat double pulley does a good job of reducing the problem.
I believe the stock fan is also a part of the problem. If the stock fan is not functioning as it should, that is, not running when not needed, then you are loading the belt/belts all the time thus wearing them out as there is not enough belt contact with the water pump/fan pulley system when the air pump is no longer installed.
Please carry a spare belt and tools to change out as the single belt cannot handle the loads imposed and will shred about once a week depending on how much driving you do. I have been caught more than once looking for both a belt and the tools to fix the problem.
If you observe black residue all over your alternator, fan etc.. it is on the way out. If you do loose the belt, do not operate the engine as there will be no coolant circulation. The temp gauge will show fine, but the engine temp is going through the roof!!
A remedy may be to simply put an idler pulley in place of the air pump. This would provide the needed contact patch for the belt that is driving the water pump.
So far I am finding the double pulley belts are wearing and not evenly, the front one is beginning to fail and I have to watch the tension frequently.
My two cents worth.
Best regards,
THC
Old Mar 31, 2004 | 08:10 AM
bliffle's Avatar
Squirt WD40 on it. Doesn't cure the slip, but disappears the squeak, and reduces heat that weakens the belt. Gotta do it every couple days.
B
Old Mar 31, 2004 | 08:25 AM
Hadoken's Avatar
WD40 is highly flammable..so don't get it on anything hot.
Just a word of caution, I know a guy who found out the hard way.
Old Mar 31, 2004 | 08:52 AM
cdrad51's Avatar
Now how could that possibly be, when the temp sensor is in the engine block? if there is no coolant circulation, the temp gauge would max out, wouldn't it?
Old Mar 31, 2004 | 09:12 AM
MosesX605's Avatar
The temp sensor is on the rad, IIRC.
Old Mar 31, 2004 | 09:18 AM
cdrad51's Avatar
Nope, that is the coolant level sensor.
Old Mar 31, 2004 | 10:55 AM
Unsupa's Avatar
Blew my 3rd one 12/8/08
your temp gauge will rise... i was going down the highway and my belt broke.. all my dash lights came on but the car was still running.. I wasn't far from home so i drove it home and the gauge got up to about 3/4..
Old Mar 31, 2004 | 11:54 AM
THC's Avatar
THC
Gents,
I have a lot to learn. Thanks for the info on the position of the temp sensor. I thought it was in the radiator also.
Now I have to admit I took a big chance twice with my 12A. I am on the way to work and accross the Ohio river bridge and the belt breaks. Like Unsupa, all the dash lights came on and I had to get to work for a meeting. I went 3 miles to the next exit, stopped for a traffic light, turned off the engine, the light turned green, fired up and got back on the interstate, drove 18 miles at 3600 rpm, 60+ mph, got off the home ramp, made the light, now operating at 30 + mph, 1 mile to go and as I turn into the drive, see the temp begin to rise above 1/2 of gage range. I am thinking probably fried the engine.
The same thing happened again at another point on the same interstate when going toward home, only this time I was near a small town and managed to get to a garage who had a belt I could use temporally. This got me to a parts house. It appears there is no damage to the 12A as it runs great.
After this experience I bought the Racing Beat double pulley and installed the two belts. But that is not a complete cure as I had to tighten the belts just two days ago and am finding the front belt is becoming looser than the rear belt??
Best regards,
THC
Old Mar 31, 2004 | 12:13 PM
cdrad51's Avatar
The engine won't fry if the temp gauge is briefly past 1/2. When you get to 2/3rds then its risking it, and if it gets to the hot zone damage is almost assured. I drove my car with my earlier engine (granted, eventually an apex seal blew, but lasted me 20,000 miles, 145,000 total) and it often went past 1/2 on the gauge. Of course the ideal is to have it at 1/3 or so, which I achieved after replacing the t-stat and radiator.
Old Mar 31, 2004 | 12:52 PM
cdrad51's Avatar
Anyways, back on the subject, I can go double pulley (have one readily available) or yoohoo belt. Which way should I go? anybody else has feedback on this? maybe I should make a poll out of this...
Old Mar 31, 2004 | 01:00 PM
Siraniko's Avatar
RX for fun
crad51,
I will be going with the SOCAL to Mazda R&D on Saturday. Cya there. I will give you pointers at that time.
Mel
