snythetic 2 regular oil?
Old Mar 30, 2004 | 06:47 PM
Fuel524's Avatar
when i first pruchased the car a month ago or so i did the tune up bit and b4 i was aware of what synthetic could do i.e. create new leaks. so i was wondering if there was something different involved in going back to conventional oil castrol gtx 10-40. i live in WA some advice would be great. i am in the process of power foaming as we speak and thought i should change my oil since my wife has been driving with me and flooding and stalling.
Old Mar 30, 2004 | 07:02 PM
Anex 570's Avatar
It Runs!
As far as I know theres one rule about doing what your talking about, and that is once you go synthetic, you cant go back. That is why they have synth-blend so you can go from regular to better blend and back if you like.
Old Mar 30, 2004 | 07:03 PM
mazdaverx713b's Avatar
Have RX-7, will restore
and why can't one go back???
Old Mar 30, 2004 | 07:11 PM
Fuel524's Avatar
ive never heard of that. it has only been in for a lil over a month about 1500 miles. i would see somthing on the lines as draining syn. filling with some cheap **** run it an hour or less then drain and fill with desired oil from there, or even a motor flush bottle in the old oil then desired oil.
Old Mar 30, 2004 | 08:19 PM
vipernicus42's Avatar
Rotoholic Moderookie
I switched back and forth from full syn to el-cheapo **** in my shadow all the time.
Unless there's a specific reason you can't switch back on a rotary, I don't see why it would matter. They're both supposed to blend together and be compatible.
Just switch back, and get your next oil change a little sooner (like half as long a time) to be on the safe side, but I wouldn't worry.
Jon
Old Mar 30, 2004 | 08:23 PM
Kai's Avatar
Kai
Rotorphile.
Unless you premix, you shouldn't use synthetic anyway.
There are absolutely no problems with switching back to regular.
Old Mar 30, 2004 | 08:34 PM
Fuel524's Avatar
cool thanks i went ahead and changed my oil a minute ago. i just thought i might ask first.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
