Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Safc S-afc 2 initialize/save settings?
Old Mar 29, 2004 | 07:01 PM
J.S.J's Avatar
Hi,
I have set up my Safc S-afc 2. I set the pressure senor, the throttle sensor, the low and high range and have set up the idle speed to subtract but I can't get it to save/preform. Each time I shut it down as I am told the set up says 0% correction. Will someone walk me through it? 93 rx7
Old Mar 29, 2004 | 07:16 PM
johnisenglish's Avatar
The initialize function ereases all data. You don't have to do anything to make it save the changes you make, it does it automatically.
I did the same thing when I had an SAFC in my last car, it took me about an hour to realize that I was ereasing the data each time I hit initialize - doh!
Old Mar 29, 2004 | 07:31 PM
razorback's Avatar
You've Been Punk'd
turn the key off, take it out the turn it back on and it should save it.
Old Mar 29, 2004 | 10:17 PM
J.S.J's Avatar
I do understand that part about erasing or writing over. The problem is I never see the correction being implemented after setting them. I will create a map and then save it but when I start it up or just view with the ignition on there's no correction it's still set a "0%" +/-.
If I set the correction for example, 800 rpm @ -5% and 1000 rpm @ -5% then press exit/ then initialize, then turn off the key and restart theres no correction it still is at "0%" +/- I must be missing a step.
Old Apr 1, 2004 | 12:08 AM
razorback's Avatar
You've Been Punk'd
do not hit initialize.
Old Apr 1, 2004 | 12:23 AM
Initialize = erase all data
matty
Jan 18, 2020 10:39 AM
