Sponsored by: CARiD
Oil Cooler Help
Old Mar 26, 2004 | 02:28 PM
SlowmoSU's Avatar
4x4 FB in the beginnings
Oil Cooler Help
Who is running a Aftermarket or self installed Oil Cooler ?
Is it on the Tranny ? Engine ? PS ?
How do you have it set up and how big is it ?
Pictures ?
I am thinking about doing one. or all 3.
but where do i put it?
on Pushing or pulling line ?
or Run it into the pan ?
or other.
Anything would help.
A.J.
Old Mar 26, 2004 | 03:14 PM
mazdaverx713b's Avatar
Have RX-7, will restore
use your stock oil cooler ONLY!!!!!!!!!!!!!! i cannot stress this enough. if you have the top mount/beehive oil cooler, convert to a front mount oil cooler from an SE or 79-83 model rx-7.
Old Mar 26, 2004 | 03:19 PM
SlowmoSU's Avatar
ok, well how about Tranny and PS lines ? coolers for them ????
Old Mar 26, 2004 | 03:27 PM
i havent heard of any really. all rotaries have stock oil coolers. the ps doesn't really need a cooler. no place to fit one. also, do you have a manual trans or auto?
Old Mar 26, 2004 | 03:46 PM
SlowmoSU's Avatar
well maybe a little more info would help this situation...
ok... taking a 13b + 5spd OUT of a doner car...
and putting them IN a Tube frame Rock Crawler....
the PS is stock pump, but its a Jeep Box.
Tranny... well its a 5 spd, but i will be making heavy use of it. since the stock ratios to wheels are like 12 to 1 and the buggy will be more like 120 to 1
so 5th gear reved out will be doing like 10-15 mph
I just want to keep everything cool as possible. since avg speed will be about 0-3 mph
Old Mar 26, 2004 | 04:02 PM
Project84's Avatar
Open up! Search Warrant!
I don't know of any vehicle that has a cooler for manual tranny gear oil. The RX-7s with auto trannys have fluid going to the lower chamber of the radiator (seperate from the coolant passages of course) and the RX-7 power steering system has a fluid line extending to the front of the car. Its there to allow air to cool the fluid in the line before it returns to the system. At speeds of 3MPH, I don't know how efficient a P/S cooler would be.
Old Mar 29, 2004 | 01:35 AM
Siraniko's Avatar
RX for fun
the PS cooler is just a piece of U-shape aluminum tubing. its mounted on the tube/reinforcement in front of the A/C condenser.
Old Mar 29, 2004 | 02:01 AM
Jaime Enriquez's Avatar
OLDROTA
Can we use the stock dual FD R1 oil coolers and run custom plumbing?
What up Wacky!
Old Mar 29, 2004 | 02:52 PM
Siraniko's Avatar
RX for fun
que pasa Jaime. I have been wanting to check out your RX-2. PM me your #.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
