Identifying a turbo vs NA tranny.
Old Mar 25, 2004 | 06:55 PM
The Spyder's Avatar
Never give up!
I have to go look at a tranny to see if its a na or a turbo. (year 88)
Are there cosmetic differences, different mounts, different connections??????
Any help appricated!
Old Mar 25, 2004 | 07:11 PM
SonicRaT's Avatar
Super Raterhater
Look at the bellhousing, the NA bell housing is smooth, and is one peice. The TII has 'ribs' on it and is bolted to the tranny.
Old Mar 25, 2004 | 07:15 PM
The Spyder's Avatar
Never give up!
So this is a Turbo tranny:
And this is a NA tranny:
Old Mar 25, 2004 | 07:19 PM
SonicRaT's Avatar
Super Raterhater
Looks to be correct, let me dig up a pic of my tII trans to verify.
Actually, on second glance they both appear to be N/A, here's a pic of my Turbo trans.
Old Mar 25, 2004 | 07:30 PM
The Spyder's Avatar
Never give up!
Had me there for a minute.....
Because those are both out of NA cars.... woohhh.....
Yeah a picture of a Turbo tranny would be helpful.
Ok I see what you mean, what year is that from??
Old Mar 25, 2004 | 07:31 PM
SonicRaT's Avatar
Super Raterhater
'88 I believe
Old Mar 25, 2004 | 07:32 PM
ajsuper7's Avatar
Nothin But a G Thang
i think turbo tranny's have two drain bolts and two fill bolts for changing the tranny oil whereas the na has one of each...i cant remeber ill go check the haynes manual
Old Mar 25, 2004 | 07:34 PM
The Spyder's Avatar
Never give up!
Sweet. Looks like the tranny Im about to go get is a NA.
Do you know if the 87' tubo tranny looks the same as a 88?
Old Mar 25, 2004 | 07:38 PM
SonicRaT's Avatar
Super Raterhater
They look identical
Old Mar 25, 2004 | 07:46 PM
The Spyder's Avatar
Never give up!
Sweet yet again! Thanks!
Old Mar 25, 2004 | 09:57 PM
RETed's Avatar
1" input shaft for turbo versus 7/8"(?) input shaft for NA.
Try and lift it - the NA isn't bad, but the turbo trans will give even weight lifters some grunts.
As a side note, there are some J-spec turbo transmissions with smooth cases!  So be careful with ribbed versus non-ribbed...boy, that sounded bad.
-Ted
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
apooch
Aug 23, 2015 10:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
