Mystery........thing!!
Old Mar 24, 2004 | 11:36 PM
Ok would someone PLEASE tell me what the container that holds antifreeze and feeds it into the carburator or intanke?? Its located on the firewall right on the passenger side and feeds antifreese like into the carb and it looks factory but i cant be certain. NO ONE can tell me what this is. WHAT IS IT!!!
Old Mar 24, 2004 | 11:48 PM
hornbm's Avatar
FD > FB > FC
its your sub zero start assist fluid.
Old Mar 24, 2004 | 11:52 PM
enigma32's Avatar
^^ As hornbm said...
It's purpose is to help the engine start when it's reeeeally cold out.
The solenoid (or is it a pump?) on mine is completely corroded over, so I don't imagine mine works.
Old Mar 24, 2004 | 11:54 PM
hornbm's Avatar
FD > FB > FC
its one of the things commonly removed. The other one is the hot start assist motor. U can trash that as well.
Old Mar 25, 2004 | 09:22 AM
Metallic_rock's Avatar
Ride 'n Style
just another thing Mazda put on there to make it cost more.... I threw mine away a long time ago...
Old Mar 25, 2004 | 09:36 AM
slashdawg00110's Avatar
RTFFAQ
You really need to get your hands on a Haynes and/or factory service manual. The answer to this and many other questions are in there.
Ditch the hot start assist and the sub-zero thing. The sub-zero unit is likely not working at all, and the hot start assist can be easily replaced by using your foot to lightly press the accel pedal on hot starts. It just cracks the throttle open a wee bit for the hot starts.
Old Mar 25, 2004 | 12:31 PM
Where is the hot start assist motor located and what does it look like?
Old Mar 25, 2004 | 12:54 PM
The_Dude's Avatar
TT 1st gen ? We'll see !
hot start assist motor is completely on the other side ... it has a cable linkage going from it to where the gas pedal linkages go ... I have my hot start assist and my sub-zero fluid in there, both work fine and My engine starts at -40 (celsius ) no problem so I'm leaving them in there. If they bust, I just wont replace them
Old Mar 25, 2004 | 02:23 PM
Ludicrous's Avatar
Drive it like u stole it
The hot start assist is right behind the strut tower on the driver's side. It's a flat thing with connectors. Mine was making a horrendous grinding noice, pulled the connectors apart, problem solved.
