cooling problems
Old Mar 24, 2004 | 06:34 PM
lemonade's Avatar
You can choose this?
cooling problems
my coolant levels are fine, ive got an electric fan from an evo 8. the battery runsat about 12v for the fan? but it still climbs above normal operating temp, and even above half way....
Old Mar 24, 2004 | 06:51 PM
red13brx7's Avatar
Is the fan pulling air through the rad? Or is it pushing against... logical question, probably a dumb one, but you never know.
Old Mar 24, 2004 | 06:54 PM
lemonade's Avatar
its blowing on the engine
Old Mar 24, 2004 | 07:00 PM
Louis M's Avatar
sure the engine isn't on fire
Old Mar 24, 2004 | 07:04 PM
lemonade's Avatar
yeah, im pretty sure its not on fire louis
Old Mar 24, 2004 | 07:16 PM
enigma32's Avatar
You checked your thermostat?
Old Mar 24, 2004 | 07:18 PM
red13brx7's Avatar
that was my next thought... check that beast
Old Mar 24, 2004 | 07:31 PM
lemonade's Avatar
its a fan run on a toggle switch
lemonade's Avatar
its a fan run on a toggle switch 1 speed
Old Mar 24, 2004 | 08:07 PM
JIMMY54's Avatar
GSL-SE PRO
Well Toggle switch doesnt really matter...unless of course its on the off postion! lol
But the two possible problems is the fan is not Pulling air through the rad (Happened to me by accident) but instead pushing. Or the thermostat...Im guessing this just started when you put the E-Fan?
Old Mar 24, 2004 | 08:24 PM
1984se's Avatar
Ryan
did you have the prob after or before the e-fan?
1st. Check you Rad. make sure that its working properly.
-run the car till the temp gets hot then when it getting war feel the top half of the rad vs. the bottom half.
if ones cooler then your rads the prob.
-then check you thermostat
-take off the housing and just replace the thermostat just to ELiMINATE that factor.
NOTE: before you install the thermostat cut off the little nipple valve thingy...
hope it works ouot for you.
-Ryan
Ian_D
Oct 14, 2015 12:31 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
carid
Vendor Classifieds
Sep 10, 2015 09:24 AM
