variable resister screw
Old Mar 24, 2004 | 03:48 PM
Fero313's Avatar
Infinite Rotary Resolve
can someone please post a pic of the variable resister screw... i can't for the life of me find it and it's bugging the crap out of me... i know it's by the passenger side strut tower but i think it's ::invisible:: can someone put an end to this madness??
Old Mar 24, 2004 | 04:11 PM
CHRISRX7F's Avatar
how i know is 2 different variable resistors.One is with screw and the other with out needed a special tool from mazda.But why you are want to adjust the variable resistor?It does not need.
Old Mar 24, 2004 | 04:56 PM
J-Rat's Avatar
Alcohol Fueled!
The variable resistor is located in the same area as the pressure sensor. It needs to be adjusted if a new motor is installed, or major maintenance is performed. You cant find the screw part, because its probably covered in anti-tamper materiel.
What "OTHER" sensor and special tool are you referring too?
Old Mar 24, 2004 | 05:03 PM
NZConvertible's Avatar
I'm a boost creep...
There is no variable resistor on S5's, so you can stop looking.
Old Mar 24, 2004 | 05:04 PM
J-Rat's Avatar
Alcohol Fueled!
lol!! I didnt even notice it was an S5.
Old Mar 24, 2004 | 05:08 PM
Fero313's Avatar
OH THANK GOD... I don't need to mess with it, but i was trying to find it one day and it's been eluding me since... i'm glad i'm not crazy (at least in that sense)
Old Mar 25, 2004 | 12:01 AM
cafcwest's Avatar
..but what does it do besides vary resistance, that is the question...
Old Mar 25, 2004 | 12:05 AM
J-Rat's Avatar
Alcohol Fueled!
Well, if you have an S4 car. It helps you set your idle by adding or subtracting fuel.
Old Mar 25, 2004 | 12:22 AM
HAILERS's Avatar
HAILERS
Your mean that you don't have to spend 300 bucks for a SAFC to get your idle to smooth out on a series four....unlike a series five??????
Old Mar 25, 2004 | 12:46 AM
J-Rat's Avatar
Alcohol Fueled!
Or you can have a combination of both..Like I do..
Andrew7dg
Aug 6, 2017 01:41 PM
kuuva86
Sep 28, 2015 05:42 AM
whinin
Sep 23, 2015 04:09 PM
