Variable resistor screw broke?
Old Mar 24, 2004 | 01:32 PM
ddub's Avatar
i am legendary
Question Variable resistor screw broke?
Yah so, looks like I've played with it one too many times and now its broken... I think. The screw spins freely in both directions and doesn't seem to change anything. I *think* this because when it was working and I would turn it to full rich the engine would start to want to die, now the idle and sound of the engine stays the same no matter how much I turn it or which direction.
Is this bad? Or should I just say "screw" it and not care
Old Mar 24, 2004 | 02:09 PM
SureShot's Avatar
Seduced by the DARK SIDE
It's only an idle fuel trim without much range.
Maybe grab one next time you're at a salvage yard.
Old Mar 24, 2004 | 02:11 PM
ddub's Avatar
i am legendary
Yah I know its only for idle, and I figured it wasn't that big of a deal. Just wanted to make sure
Old Mar 24, 2004 | 02:43 PM
HAILERS's Avatar
HAILERS
It sounds busted. I'd disconnect its plug. The ECU will default to some value.
Or backprobe the output wire on the thing and watch the output voltage as you turn the srew. I think mid range is 2.5 volts.
ls1swap
Jun 3, 2024 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Sethix
Nov 3, 2017 11:48 PM
Andrew7dg
Aug 6, 2017 01:41 PM
wthx100
11
Oct 1, 2015 10:23 PM
