turbo help
Old Mar 23, 2004 | 06:44 AM
fc313bt88's Avatar
Question turbo help
is it possible to run a t04 or t3 t4 on stock ecu w/safc and fuel upgrades
Old Mar 23, 2004 | 08:13 AM
rotoboy20's Avatar
Im Ron Burgandy..
it would also be wise to have a fuel cut defender, im sure you alreay thought of that but, it seems as though you might be running higher than normal boost. correct? just trying to help!
-chris
Old Mar 23, 2004 | 08:15 AM
rotoboy20's Avatar
Im Ron Burgandy..
you might also wanna check to see if those turbos will bolt up to your exhaust manifold. you might need an after market one. other than that i dont see how it wouldnt be possible.
-chris
Old Mar 23, 2004 | 03:31 PM
fc313bt88's Avatar
yeah i have fcd and all the stuff to support 300-400hp to much boost for stock s4 turbo yeah have t04 exhaust man just need to know if stock ecu can handle it ill have to keep boost down with boost cont and use safc to help with fuel
Old Mar 23, 2004 | 07:57 PM
J-Rat's Avatar
Alcohol Fueled!
Yes
Old Mar 23, 2004 | 08:24 PM
rx7lover0147's Avatar
flamehead
i am thinking of going with this setup: raceported t043 turbo with t04 manifold, walboro 255 fuel pump, intake, 3" exhaust, and am wondering if i should also need to run a fmic and what kind of other fuel mods i should do i also plan on going haltech. sorry to take up your post but i've been wanting to ask these questions and by god you already started the topic of the t04
Old Mar 24, 2004 | 06:51 AM
fc313bt88's Avatar
you should use 720cc or bigger injectors and fmic i heat soak stock tmic very easy with stock turbo.
need to know best specs on to4 for stock ecu w/safc im sure it would have to spool close to stock or does it matter will have haltech in a few months but need new turbo soon
Old Mar 24, 2004 | 06:46 PM
flamehead
so use both primary and secondary 720cc injectors or what i really need to know kind of a newbie as of fuel injectors and fuel delivery
Old Mar 24, 2004 | 06:54 PM
Infini IV's Avatar
Microtech Tuning!
Yes, just keep boost low because there is not really a way to retard timing more.
BTW, boost controller does NOT lower boost!!!
Old Mar 24, 2004 | 06:58 PM
Sir Rupert Hobo's Avatar
seven-less
you'll probably need bigger secondaries than that and a walbro. also i would think your timing would be way off if you were to run that much boost.
Old Mar 24, 2004 | 07:41 PM
flamehead
i have a haltech so i can fix that what kind of secondaries should i run then if i wanted to push at the most 19 psi but that would be the most
Old Mar 24, 2004 | 10:22 PM
Sam's Avatar
Sam
big boost baby
yes sean, but the stock ecu doesn't retard the timing past 8 Psi. you need to make sure the SAFCII does that.
you still running open downpipe?
Old Mar 24, 2004 | 11:14 PM
seven-less
i'm sorry, i got you and fc313bt88 mixed up. to answer your question, i would think 1600cc would be enough. you'll be running a pretty powerful setup so you may need a competition fuel pump also, just to be on the safe side.
someone wanna correct me if i'm wrong?
ps. this is why i can't wait till henrick finishes his ecu upgrade. it retards timing ~1 deg for every PSI after 9...
Old Mar 25, 2004 | 07:07 AM
fc313bt88's Avatar
sweet about ecu upgrade have price on it sam still open down pipe lets run sat night i want to run about 10-14psi on t04 with stock ecu or good upgrade ecu waste gate controlls boost so boost controller would just help out
Old Mar 25, 2004 | 09:35 AM
pip's Avatar
pip
the blackest incarnation
Dont mean to hijack this thread, but does that mean you dont run an fcd with his ecu chip? Seeing as if you were running the fcd the ecu would never know you hit over 8 psi.
Old Mar 25, 2004 | 01:47 PM
seven-less
it has one already built in
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
