Crush nut?
Old Mar 22, 2004 | 10:13 PM
Crush nut?
Apparently I need the crush nut on the half shaft that you can see when you take the center cap off. Does anyone know where i can get it from? Any help would be appreciated.
Craig
Old Mar 22, 2004 | 10:25 PM
BTW, I already asked the local Mazda dealership and they couldn't tell me how much it would be. They said it comes with a bunch of stuff, i guess wheel bearings or something and they can't sell just the crush nut.
Old Mar 22, 2004 | 10:58 PM
Audiofight's Avatar
Find a factory parts diagram and verify what the dealership told you.
When I broke a tooth off my flywheel ring gear, they told me they didn't sell just ring gears and I had to buy a whole new flywheel. I located the ring gear part number and when they punched it in, it was valid and still in stock.
See if you can locate an individual part number first, before giving up.
Old Mar 22, 2004 | 11:01 PM
Project84's Avatar
Open up! Search Warrant!
did you check mazdatrix?
Old Mar 22, 2004 | 11:06 PM
I checked mazdatrix. I used the search button there, but it didnt come up with anything. I also looked in all of the sections that i thought were relevant, but no luck.
Old Mar 23, 2004 | 01:48 PM
vaughnc's Avatar
knowledge junkie
Check the 89-90 or 91-92 parts diagrams. Download them from rx-7 2nd gen section on www.mazdaformance.com
BTW - mazdaformance is usually much cheaper than the dealership. Email them the part # for a quote.
Old Mar 23, 2004 | 02:24 PM
HAILERS's Avatar
HAILERS
I bought 'em from PepBoys.
Old Mar 29, 2004 | 01:52 PM
I don't think we have a Pep Boys. Is that like an Advance Auto, or Autozone?
Old Mar 29, 2004 | 02:02 PM
Hot_Dog's Avatar
Re: Crush nut?
Craig
Mazda sells them. The last time I bought them, which was several years ago, they cost about $12 each. BTW, I've been using (and re-using) those nuts without crushing the collar...just check them for tightness everytime you rotate tires.
Hot_Dog
90 RX7 GXL
02 Acura RSX-S
Old Mar 29, 2004 | 02:17 PM
HAILERS's Avatar
HAILERS
Those are supposed to be selflocking nuts. But if you did not destroy the old ones ....use them again. After torquing the nuts you are supposed to stake the nut to the grooove. That staking plus the torque should be good enough.
