Need help, starting issues
Old Mar 22, 2004 | 02:11 PM
The Spyder's Avatar
Never give up!
First off, we switched the tranny/driveshaft last night. The engine ran perfect before, and we have double checked all the wires. The only thing we haven't done is replaced the plugs. The engine turns over, and half the coil packs are detinating, but it still won't catch. Any advice?
Old Mar 22, 2004 | 02:44 PM
The Spyder's Avatar
Never give up!
The plugs look fouled, going to replace them and see how it works..
Old Mar 22, 2004 | 04:51 PM
The Spyder's Avatar
Never give up!
No one has any clue
Replaced the plugs, got spark, NOTHING.
Old Mar 22, 2004 | 04:54 PM
Icemark's Avatar
compression???
sure it's not just flooded?
Old Mar 22, 2004 | 05:09 PM
BraveBlueMice's Avatar
Everytime I work on my GXL, it gets flooded on the first startup attempt. I use the following method to get it to do something:
Unplug MAF, and crank relentlessly until it starts, then dies. Reconnect MAF, and start normally.
But then I get this white fog out the exhaust. It looks like a rock concert in my parking lot. The fog smells like fuel, and the engine runs like crap and dies. I haven't cured the problem, only overpowered it. Any advice would be greatly appreciated.
Old Mar 22, 2004 | 05:59 PM
The Spyder's Avatar
Never give up!
MIGHT be flooded, but we have let it sit for a period of a few hours between trying... I don't think it is comp, we just swapped a tranny, would that do it? We will try the MAF trick..
Old Mar 22, 2004 | 06:19 PM
The Spyder's Avatar
Never give up!
Removed MAF, cranked until it flooded (for sure this time ) looked over the engine and found a loose sensor, and am currently waiting for it to dry out.
Also, there is a sensor on the clutch slave cylender, and the wire broke off of it. A little black box, with the word "Delta" on the top of it. What does this do, where can I get a new one, and would it cause problems?
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
FB_Frank85
Aug 31, 2015 03:31 AM
befarrer
Aug 14, 2015 04:18 PM
