2 miles and needing more gas
Old Mar 21, 2004 | 11:21 PM
OriGiNaL TyPe R's Avatar
rEv got me gOne
Unhappy 2 miles and needing more gas
good day/night gent/ladies(if any)
i got an 84 se and it burns a lot of gas ...no smoke and the oil preesyre gauge shows compression to be okay...i've had mostly gsl's(12a) and had 1 se but don't remember it burning gas like this..15miles starting on a 1/2 tank , and by the time i drive the 15 miles it a little past 1/4...i also was told that this model(se) has a third injector (cold start) and that they get stuck..where is it? i've readmy hayes and can't find it..by the way should there be a ticking sound (sounds like a fuel injector{ticksfaster when i raise the rpm})should it be making noise..i don't remember my other se making that sound.
help anyone fuel prices are raising..:o
Old Mar 21, 2004 | 11:27 PM
peejay's Avatar
Old [Sch|F]ool
Are you sure your fuel gauge is reading correctly?
BTW there is no cold start valve.
Old Mar 21, 2004 | 11:42 PM
rEv got me gOne
no cold start....oooohhh. well when i fill it up the meter moves to fyll ...and when i turn corners it goes up and down so i think it's working
Old Mar 21, 2004 | 11:44 PM
peejay's Avatar
Old [Sch|F]ool
How many gallons from 1/4 tank to full, or from 1/2 tank to full?
It should be about 9-10 gallons to go from 1/4 to full.
Old Mar 22, 2004 | 12:14 AM
YapaKanichi's Avatar
Smile Like a Donut
is the car ported or have an aftermarket carb on it? Do you romp on it as well? Both of those are huge factors.
Old Mar 22, 2004 | 02:16 PM
©ØÐËߣüË's Avatar
Post Pimp
i had the same thing happen to my car and i could not figure it out . come to find out i had a leak in a fuel line . when steped on the gas the faster it would leak out . also look at you fuel pump see if you see any leaks .
Old Mar 22, 2004 | 09:09 PM
rEv got me gOne
_________________________________________is the car ported or have an aftermarket carb on it? Do you romp on it as well? Both of those are huge factors.
____
no the car is stock se.. get in to it once in a while..i think its a bad injector...something is making a ticking sound under the hood..
checked under the car no leaks that i could see( car was on a lift)...i really don't want to take it to the dealer ...don't trust dealership
Old Mar 22, 2004 | 09:27 PM
my brothers injectors would tick when they went bad in his sentra....
Old Mar 22, 2004 | 10:22 PM
smnc's Avatar
EliteHardcoreCannuckSquad
That's probably your solenoids... Check your TPS...
Old Mar 22, 2004 | 11:04 PM
Tiers's Avatar
Ticking can also be the OMP (oil metering pump) check if it is operating ok and not leaking
Old Mar 23, 2004 | 09:14 AM
mwatson184's Avatar
holley guy
I am going to guess you have a gas leak somewhere, or your fuel level sender is whacked out. I doubt you are getting 4 miles per gallon.
Old Mar 23, 2004 | 10:12 AM
Your fuel damper leaking?!!??!
Old Mar 25, 2004 | 10:12 PM
rEv got me gOne
sorry for the dealay in responding (work long hours), up early home late..79-84 rex thanks for the insight...i was told about the damper thing to and will check on the as well test the injector for resistance..proper working order.
smnc...
i will check that as well thanks
tiers....
the ticking is coming from the top of the throttle body... but i could be wrong ...i'll check that as well..
again thank to all...
Old Dec 27, 2010 | 03:05 PM
rEv got me gOne
the fix was my injectors needed to be replaced.
Old Dec 27, 2010 | 03:50 PM
Keith13b's Avatar
Originally Posted by 79+80+84_rx-7
your fuel damper leaking?!!??!
+2 for this!
Oops - saw you got it fixed - I replied before I read the whole thread!
Old Dec 27, 2010 | 09:58 PM
IanS's Avatar
Ricer
I say congrats on owning your car more than 6 years AND remembering what the problem was that long ago.
alphawolff
Nov 17, 2015 05:57 PM
smikels
Aug 18, 2015 01:26 PM
