12a Front Cover to 13 BT
Old Mar 20, 2004 | 03:27 PM
CheddaKing's Avatar
When swapping the 12a front cover onto a 13BT(s5) Does anything need to be swapped over? I'm Running premix so dont worry about the OMP, I'm also alreay done with a turbo oil return, just making sure im not missing anything...
Old Mar 20, 2004 | 03:39 PM
setzep's Avatar
You got it! you can take the shaft and gear out for the omp if you like also.
Old Mar 20, 2004 | 04:08 PM
CheddaKing's Avatar
Cool, im just wondering about the oil pressure control valve now, is the 12a one ok in there or should it(can it?) be swapped out for the tII one
Old Mar 20, 2004 | 08:40 PM
680RWHP12A's Avatar
yah good idea!!
as far as the oil reg. goes the 12a one will be fine
Old Mar 21, 2004 | 10:46 AM
CheddaKing's Avatar
thanks, problem solved, engine goes in today!
Old Mar 22, 2004 | 06:52 AM
KehoeAutomotive's Avatar
I weled a plate to the front of the engine and tapped 4 holes for the mounting plate.
No swapping needed. Or gaskets etc. Just a thought.
Old Mar 22, 2004 | 08:35 AM
CheddaKing's Avatar
Too late, already swapped over the cover, i actually did consider your idea, but decided against just because i had the front cover available... The turbo return is already tapped, OMP blocked off, etc, All that is left for me is throwing the engine in and hooking up my beautiful new microtech!
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
morataya
Microtech
Aug 17, 2015 01:04 PM
