Turbo Oil return alternative
Old Mar 17, 2004 | 03:41 AM
Gregs's Avatar
i was thinking about it, 99 percent of stock cars with turbos dump the oil from the return into the oilpan, i know alot of first gen turbo guys if not all run the return to the front cover, i was just thinking and i really think it would work, have the turbo oil return go back into the oilpan, get a fitting drill tap bam yer done!
now i really havent heard of anyone doing this on a turbo first gen setup, is there something im missing?
i want alot of feedback on my idea
thanks guys!
-greg
Old Mar 17, 2004 | 04:13 AM
680RWHP12A's Avatar
you can do that but remember the turbo is gravity drain,,,, so.... you would have to run he oil level lower than the fitting in order for it to drain properly.....hence thats why the factory put the drain where it is....p.s. your fpr is on its way!!
Old Mar 17, 2004 | 06:52 AM
KehoeAutomotive's Avatar
There waas a thread about this recently. I decided to install the return line in the front cover but after reading about several peopel who went back to the pan; I did it that way.
It was much easier and cheaper that way.
Thanks for sharing your thoughts.
Old Mar 17, 2004 | 01:18 PM
coldy13's Avatar
Yeah, shutup kid.
How is it cheaper to do it in the pan? Just drill the front cover, tap it, and put in the fitting. Pour some diesel straight through the oil system to clean out any shavings that might have gotten in. I don't see why putting the return in the front cover is considered "hard".
Old Mar 17, 2004 | 03:06 PM
Jeff20B's Avatar
Lapping = Fapping
I drilled and tapped a front cover just yesterday. Easier than doing the oil pan.
Old Mar 17, 2004 | 07:50 PM
mar3's Avatar
Administrator
While it was on the engine, also? Pulling the pan is a lot easier than pulling the front cover....
Old Mar 17, 2004 | 08:00 PM
web777's Avatar
I think you meant "while it's in the car". But yes, that's why it's easier. And if you have a low mounted turbo like me, the front cover is too high.
Old Mar 17, 2004 | 08:43 PM
Gregs's Avatar
yeah my turbo is pretty low, ill figure it out
-greg
Old Mar 17, 2004 | 09:13 PM
seanrot's Avatar
Always waiting for parts!
Jeff20b can I borrow your drillbit and tap? at least what sizes did you use?
Old Mar 17, 2004 | 09:14 PM
seanrot's Avatar
bp whoops
Old Mar 18, 2004 | 02:51 AM
Jeff20B's Avatar
Lapping = Fapping
7/16 drill bit and 1/4 NPT tap. This is your typical Camden supercharger oil return fitting. http://www.camdensuperchargers.com/index.php?pag=305
Old Mar 18, 2004 | 06:53 AM
rotary emotions's Avatar
HEAVY METAL THUNDER
in order to allow the oildrain to work properly Elford (uk) had a sort of collect can mounted next to the pan, which overflowed into the pan. This is a whole lot more work then a "simple" front cover mod. I guess they'll know why they did this that way instead of simply draining to the pan. This way they could drain the oil without having to worry about the drain being under the oillevel.
Old Mar 18, 2004 | 08:47 AM
coldy13's Avatar
Yeah, shutup kid.
I drilled and tapped my front cover while it was still on the engine in the car. Wasn't a problem at all.
Old Mar 18, 2004 | 09:12 AM
seanrot's Avatar
coldy did you drill and tap in the same spot as camden super chargers or did you do the oem spot on the jspec engines?
Old Mar 18, 2004 | 01:20 PM
coldy13's Avatar
Yeah, shutup kid.
I tapped where there was the indent on the front cover, right next to/below the OMP.
Old Mar 18, 2004 | 01:47 PM
seanrot's Avatar
Well, I just got a 1/2 npt tap off ebay, now I'm looking for a 45/64 drill bit. cant find one will fit a 3/8 chuck so I think im going to go with a 11/16 inch bit its only 1/64th off. I'm hoping the soft aluminum will be forgiving for the 1/64th. I have another front cover that I'm going to try it on first.
Old Mar 18, 2004 | 01:57 PM
CheddaKing's Avatar
I did the same thing, worked fine, just try and wiggle/dremmel out the extra 64th.(i used the dremmel, worked well)
Old Mar 18, 2004 | 02:20 PM
Jeff20B's Avatar
Lapping = Fapping
I drilled mine in basically the same spot as in the camden pictures. My OMP was in the way, so I had to hold the drill motor so it wouldn't hit the OMP. It still looks like the fitting is in almost the exact same position, though. Close enough for me, anyway. The front cover was on the engine, but the oil pan hadn't been installed yet.
Yeah, the 7/16 drill bit cut through the aluminum very quickly because I already drilled a pilot hole. Man, it cut so fast, and then the tap cut very fast too. I hardly had time to enjoy the process.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
