Oil Leaking
Old Mar 16, 2004 | 11:27 PM
dark mephisto's Avatar
Rotating once again!!
Oil Leaking
I've been looking at my seven for a while now, and I've noticed a **** load of smoke coming from it, its leaking oil from somewhere around the carb, and then its dripping onto the themal reactor and burning. Has anyone else had this kind of problem? Can you help me?? Thanks. O-yeah its an 81.
Old Mar 16, 2004 | 11:30 PM
mazdaverx713b's Avatar
Have RX-7, will restore
its probably your oil metering pump gasket leaking. btw, you have an 81, it is not equipped with a thermal reactor, it has the manifold and catylitic converters, unless it is a pre 1981 engine. dave
Old Mar 16, 2004 | 11:35 PM
check those two little plastic lines that run from the front of the motor, on the exhaust side, up, over the radiator hose and into the driver side of the carb.... two little plastic lines, that you definatly want to have.... feeds oil to the motor to keep the seals lubricated and keep the comp up....
Good luck..... if thats not your problem, I dunno what is....
Old Mar 17, 2004 | 03:47 PM
umm, my car has a thermal reactor, i thought that the catylitic converters didn't come out until 82??
Old Mar 17, 2004 | 03:55 PM
cdrad51's Avatar
Lorem ipsum dolor sit ame
as stated the dripping into the heat shield is typically the omp leaking.
Old Mar 17, 2004 | 03:57 PM
Anex 570's Avatar
It Runs!
Your more then likely right, do you have only 1 cat looking thing and a oval pill looking thing for a maniold, and a tube that runs to the side of your muffler?
Old Mar 17, 2004 | 05:30 PM
umm, the only thig that i really have is a thermal reactor bolted to the side of my engine, then thers a hose that connected to the acv, and then a pre silencer, and then my muffler. And WTF is an OMP?? and how do I fix this??
Old Mar 17, 2004 | 05:37 PM
cdrad51's Avatar
oil metering pump. Do you have a Haynes? it explains how to check the omp and handle as needed.
Old Mar 17, 2004 | 06:49 PM
yeah, i'll get right too it. If thats not it, i'll re-post this. Tanks for your help.
Old Mar 18, 2004 | 11:01 PM
it turned out to be one of the little plastic hoses, the rubber broke off, so i just slid it back on and it is no longer leaking, but i just found out that my oil cooler line on the bottom is leaking just a bit, right where it connects to the oil cooler, is there a cheap quick fix to this?? or do i have to replace the whole line??
rotor_veux
Sep 3, 2015 07:10 PM
sypath
Aug 16, 2015 12:06 AM
