HELP! intake manifold question for you SE owners.
Old Mar 14, 2004 | 02:21 PM
13BTOY's Avatar
Boosted Fb
I'm using the SE lower manifold with my car set up. I was wondering if you can help me identify the nipple(1/4in I think) fitting on the top mid section on the lower manifold(right next to the block). I have no clue whats it for so I just capped. Doe is have vacuum?
Thanks, Ed
Old Mar 14, 2004 | 02:43 PM
gsl-se addict's Avatar
Super Moderator
There are two fairly large nipples on the back of the intake manifold. One is for the brake booster and the other is for air injection into the main cat converter.
Kent
Old Mar 14, 2004 | 03:27 PM
RacerX7fb's Avatar
paradox
Whats your car set up
If its a fitting for a hose on the top middle part of the lower intake manifold then yes it has vacuum.. for the air bleed sockets within the center housing.
Old Mar 14, 2004 | 05:43 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Are you talking about the one under the oil injectors?
That's the connection for the Cold Start Assist System.
I just removed mine. Just cap it off and don't worry about it.
Old Mar 14, 2004 | 08:57 PM
13BTOY's Avatar
Boosted Fb
Racerx7, I meant to type my carb set up. Anyways its a dellorto with RB upper. I wanted to know if that nipple(in front tucked between manifold and block) had vacuum so I can use it for the CCV install.
Thanks, Ed
Old Mar 14, 2004 | 10:37 PM
13BTOY's Avatar
Boosted Fb
smnc, thats the one!
Thanks, Ed
Old Mar 15, 2004 | 12:10 AM
RacerX7fb's Avatar
paradox
Since its now carbed... you did the right thing and plugged it up
Engine stand ready
Aug 14, 2015 10:26 PM
