still no fire
Old Mar 10, 2004 | 09:14 PM
capri93's Avatar
The thing
still no fire
i checked all the fuses and plugs are new, used starting fluid. turns over and half *** fire once in a while what should i check next i noticed theres a small condencer on the top of the motor could this be the problem or could i have screwed somthing up when i hooked the battery up in reverse what else might be wrong
Old Mar 10, 2004 | 09:17 PM
BigJim's Avatar
trainwreck
Check for spark(prolly already did it), then your fusible links i would guess. Dont rlealy kno thou
Old Mar 10, 2004 | 09:32 PM
vipernicus42's Avatar
Rotoholic Moderookie
Spark + Fuel + Compression = running engine
So your spark plugs are new. How new are your plugwires and your distributor cap/rotor? If you don't know, or don't remember when they were changed, then you should look into changing those. Use the Heynes manual to check for spark.
To me though, it sounds like you're flooded. Pull the plugs and check if they're wet. If they are, disconnect the fuel pump, crank it a few times with the plugs out, wipe the plugs off, put it all back together and try again.
If they're not wet, perhaps you're not getting proper fuel. Check your fuel filter. 5 bucks and 5 minutes (it's just in front of the tank on the driver's side, bloody easy to replace).
Fusibles won't really cause starting problems like that... they'll cause electrical problems like a complete lack of starter, and headlight problems, but if it's cranking, it's soemthing else.
Jon
ls1swap
Jun 3, 2024 03:25 PM
Aramir
Oct 18, 2015 02:39 AM
LongDuck
Oct 7, 2015 08:12 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
