oil everywhere! please help
Old Mar 8, 2004 | 07:49 PM
rx-7ames's Avatar
i have an 84 gs. the engine only has about 30,000 miles on it but it is allready covered in oil. it is mostly on the drivers side. i believe it is leaking from the seals under the oil cooler but i'm not sure.is this a commen problem? would this be hard to fix? where would i need to get new seals for this? please help me with any information you can give me. thanks.
Old Mar 8, 2004 | 08:07 PM
Lotus00's Avatar
It is very common, you will need to replace the o-rings on the oil cooler. better yet, get an oil cooler from a series 2 car (81-83). you would have to custom mount it, but its a lot better than the behive
Old Mar 8, 2004 | 09:06 PM
rx-7ames's Avatar
thanks. has anyone posted any threads on 81-83 oil cooler conversion? i will consider this if i can find an oil cooler and it isn't too difficult.
Old Mar 8, 2004 | 11:17 PM
rhinor61's Avatar
The modification you want is '79 thru '82 US made Rx-7, with the air to oil cooler.
Parts needed:
Short radiator
Oil pedestal (2 new oring)
Oil cooler with mt. brackets
Oil cooler hoses, short and long
Radiator shroud for short radiator
Rubber cap with clamp to plug t- outlet port.
2 or 4 crush washers for hoses..
If your tall radiator is NEW then you will want to with a GSL-SE oil cooler and mt. it in front of the radiator.
Not hard to do, just look at a donor car.
John
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
