Remove driveshaft, tranny fluid spills out, normal?
Old Mar 8, 2004 | 10:31 AM
82transam's Avatar
Never Follow
Should the tranny fluid spill out the back of the trans after removing the driveshaft? Or does that mean the tail shaft seal is bad? Also, while the trans is out, is there anything I should do prior to reinstalling, like new seals or anything? I don't want to rebuild it, as it works pretty good, but is there anything simple I could do to it? TIA
Old Mar 8, 2004 | 10:37 AM
Crash Test Joey's Avatar
Zero Rotor Motorsports
Re: Remove driveshaft, tranny fluid spills out, normal?
It's normal. Most tool makers (snap on, craftsman, etc) actually make sets of caps in different sizes to plug the tailshaft so you don't make a mess.
Old Mar 8, 2004 | 10:39 AM
mazdaverx713b's Avatar
Have RX-7, will restore
you may want to replcae the output shaft seal while you are doing this though.
Old Mar 8, 2004 | 10:56 AM
Metallic_rock's Avatar
Ride 'n Style
that's why I back my car up on ramps to ensure that the oil doesn't pour out... Yes, it's very normal.
Old Mar 8, 2004 | 10:59 AM
82transam's Avatar
Never Follow
ok thanks guys, I figured it was normal because it happened with my parts car when I pulled that engine too.
Old Mar 8, 2004 | 11:47 AM
DriveFast7's Avatar
Blood, Sweat and Rotors
I STICK a spare driveshaft yoke in there when removing the driveshaft. keeps fluid from spilling.
Old Mar 8, 2004 | 12:04 PM
GavinJuice's Avatar
Leave A Message
always replace the seal, no point in re-using something that is already mangled
Old Mar 8, 2004 | 08:26 PM
82transam's Avatar
Never Follow
yea thats what i figured, are there any easily accessible seals up front to worry about?
SCinfidel
Sep 8, 2015 05:36 PM
risingsunroof82
Sep 7, 2015 01:11 PM
Frisky Arab
Sep 4, 2015 06:17 PM
