how to tell if my engine has been rebuilt?
Old Mar 7, 2004 | 07:02 PM
I already searched. I bought this car some time ago as a repo item so i know nothing about its past. I was wondering how to tell if a company has rebuilt your engine. The car has 121,xxx miles on it so i would imagine it would but im not sure. Also how can i tell if it's been street ported? Is the only way to tell is if it has a lumpy idle.
Old Mar 7, 2004 | 07:10 PM
skunks's Avatar
I'm a CF and poop smith
you can snake a Colonoscope/Sigmoidoscopy/fiberoptic camara in to your LIM and check to see if your intake runners are ported or thru your downpipe, past your wastegate and check to see if your exhuast part is ported. other then that, pull your engine apart and take a look
Note: it will cost between 2-6k for a Colonoscope/Sigmoidoscopy/fiberoptic camara... try to find someone with one which trust you with it. also, i should not have to say things but... dont even try to turn your engine on with it in your engine.
Old Mar 7, 2004 | 07:13 PM
haha very funny skunks
Old Mar 7, 2004 | 08:06 PM
NukeGenius's Avatar
Dim Sum owns you!
Take it out, rebuild and port it, then you know when it was rebuilt last and how it was ported. Even when you do buy a car from somebody else, unless they left it stock, you really have no idea FOR SURE about everything that has been done to the car. Who knows how many little ghetto mods have been done that owners forget about.
Old Mar 7, 2004 | 08:18 PM
skunks's Avatar
whats so funny??? i used one just today to find out if my starter pinoin gear was contacting my flywheel ring.
http://www.medisource.com/categoryli...0Endoscopy.htm
just find a doctor which will let you use his just dont tell him what your gonna use it for haha
Old Mar 7, 2004 | 08:20 PM
skunks's Avatar
double post
Old Mar 7, 2004 | 08:22 PM
skunks's Avatar
the one i used looked like this http://www.labx.com/web/rankin1/imag...?pic=14868.JPG
it maximum diameter is 13.3mm, easily able to make it thru the intake runners and in to the ports to see if indeed you ahve a ported engine
Old Mar 7, 2004 | 09:28 PM
dgeesaman's Avatar
Uhh, I really wouldn't know what to tell him then. Unless you're into side-job colonscopies.
Dave
Old Mar 7, 2004 | 09:33 PM
skunks's Avatar
Dave
everyone likes to look inside themselves once in a while
Old Mar 7, 2004 | 09:34 PM
TwinTriangles's Avatar
What's an RX-7 ?
Allot of times you can tell by pulling the oil pan off and looking at the seems between intermediate housing and rotor housings, Usually if its not a factory replacement and it is rebuilt they will use silicone to seal it back up better...
Old Mar 7, 2004 | 09:42 PM
Jesuscookies's Avatar
I can haz rotary?
Just run a compression test. That should be enough to at least know the general health, compression wise.
Old Mar 7, 2004 | 09:57 PM
skunks's Avatar
well if you are going thru the trouble of pulling off the oil pan, you might as well rebuild the entire engine as you problaly pulled it from the car to take hte oil pan off. at least tahst what i would do
Old Mar 7, 2004 | 10:16 PM
RxSeven1's Avatar
you can tell its a mazda reman if there is a blue placard on the front of the motor
Ciclovnz
Oct 18, 2015 03:04 PM
rxmiles
Aug 24, 2015 02:07 PM
ncds_fc
Aug 15, 2015 10:06 AM
