Sponsored by: CARiD
engine rebuild question
Old Mar 7, 2004 | 06:25 PM
rx7_rat's Avatar
when you look in the service manual it talks about a "soft material coating" and i was wondering if i sent the engine to a maching shop to be cleaned like the rootor housings, rotors, ect. if it would destroy or remove the coating. it is for a 91 n/a. thanks
Old Mar 8, 2004 | 03:36 AM
RETed's Avatar
Why don't you ask the machine shop about it?
-Ted
Old Mar 8, 2004 | 10:58 AM
mazdaverx713b's Avatar
Have RX-7, will restore
you will need to have the housings lapped as well as cleaned. my suggestion would be to send the housings to a reputable builder like mazdatrix, atkins, racingbeat, and they will lap and clean. or just try calling one of the builders and ask. btw, the coating is metal, not a lubricant.
Old Mar 8, 2004 | 04:59 PM
rx7_rat's Avatar
the service manual just says take care not to damage the soft coating so i was wondering if having the machine shop clean the parts would it hurt the soft material.
Old Mar 9, 2004 | 12:35 PM
no, they mean not to throw it around and chip it. like i said before, its a metal coating. but you will need to lap the housings. its like honing a cylander so that the piston rings will seat in properly.
Old Mar 14, 2004 | 06:10 PM
Richard Miller's Avatar
Damn, it did start!
I have heard that lapping removes the coating and greatly increases wear on the side housing. Essintially it is better to have a housing that is in spec than to lap one into spec. can anyone give an opinion on this?
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
