CAT glowing ORANGE. WTF?!?
Old Oct 24, 2001 | 07:55 PM
ItsNiceToBurnRice's Avatar
I started my car up today, 88 GXL NA, for about 10 minutes, and was revvin it up quite well at one point. For the hell of it I got out and looked under my car, I think its one of the cats, Im not sure-Ive only had this car not even a week now, but anyways its the thing right before the pipes "Y" of in the back. It was glowin orange where the straight part of the Y goes into it. Then after like 5 minutes it was fine. WTF?
Old Oct 24, 2001 | 08:01 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
the cat was probably clogged and you blew out a hole in it finally would be my first guess. see if you can get a sniff test done someplace and see if the cat is still good.
Old Oct 24, 2001 | 08:02 PM
Ryde _Or_Die's Avatar
Better yet, take the cat off and clean it out
Old Oct 24, 2001 | 09:06 PM
Mike W's Avatar
does it smell like rotten eggs too? thats not uncommon if a cat is glowing like that, but its deffinately clogged
Old Oct 24, 2001 | 09:12 PM
MaxRX7's Avatar
hambre y sueño
same thing happened to my precat #1, that little ****** farted and smelled like rotten eggs
Old Oct 24, 2001 | 10:30 PM
Well
It was only glowing for like 5 minutes, still mean its clogged? maybe that would explain my rough idle. and is there anyother way to unclog it besides takin it off?
Old Oct 24, 2001 | 10:57 PM
Mike W's Avatar
no. if its glowing then it is definately clogged. . to fix that you have to take the cat off. and you have to options. 1-gut the cat. 2-replace it, preferably w/ a high flow cat. the rough idle may be fixed by replacing/gutting the cat. many people have that problem w/ thier cars
Old Oct 24, 2001 | 11:31 PM
Just gut it You know you want to
Old Oct 25, 2001 | 05:46 PM
YEah i do
I would love to gut it, but i live in Ohio, the land that holds the E-check. So guttin its not an option. ****, if I have to take it off, that means even more leaks.damnit
Old Oct 25, 2001 | 06:16 PM
Anyone know if a clogged cat will make your run hotter? I would think so, havin heat prblems here, trying to diagnose the problem.
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
