Fuel Injection Vs Porting
Old Feb 24, 2004 | 11:03 AM
Xavier8's Avatar
Never satisfied
I am currently beginning a project to put a 1st or early 2nd gen 13b into a Triumph Spitfire. I have been thinking I would want a fuel injected motor to get the most power and reliability, but this setup also adds quite a bit of complexity to the project. Can I use a carburated motor and make it decently powerful through carb changes/porting without breaking the bank? I would ideally want 150hp at the crank, and since the FI motor makes 140 from the factory, this would come close to my needs. Any thoughts?
By the way, would I have to use an RX7 guage cluster to run the fuel injected motor from the 1st Gen 7?
Old Feb 29, 2004 | 10:56 AM
mazdaverx713b's Avatar
Have RX-7, will restore
you can use a carb on any wngine you put in the vehicle. you could use the gauges, but you do not have to. a carb'd engine will be the way to go. if you add a decent carb, a good exhaust and go direct fire, you will be in the ballpark to having a very quick car.
Old Feb 29, 2004 | 12:08 PM
Directfreak's Avatar
I am a Jeeper Now.
Definately go aftermarket carb (weber) with aftermarket gauges. Stewart Warner makes some nice "classic" looking gauges which are backlit properly and look beautiful.
Old Feb 29, 2004 | 03:23 PM
KehoeAutomotive's Avatar
A carb would work fine but you would not have to ues the gauge cluster out of your RX.
Direct Freak is right; Use callsic looking gauges.
Th0m4s
Feb 26, 2019 02:04 AM
dkwasherexd
May 27, 2017 04:51 AM
Josh83rx7
Sep 2, 2015 05:57 PM
