engine check q?
Old Oct 23, 2001 | 01:28 PM
Josepi's Avatar
Despise Enmity
engine check q?
Just wondering, in order to pull the codes from a 91 TII, all the instructions I read say to ground the 1 green plug up front. Do you keep it grounded the whole time (IE stick wire in it to the - of the battery, hop in and turn the key)?
TIA
Old Oct 23, 2001 | 01:43 PM
cymfc3s's Avatar
I Raise Chickens
ground the single green connector near the leading coil. Turn the key and the 'check engine' light will flash the codes. To reset the codes, unplug the POSITIVE terminal on the battery, and depress the brake pedal for a few seconds.
Old Oct 23, 2001 | 02:10 PM
Josepi's Avatar
Despise Enmity
So do you leave it grounded while you are pulling codes?
Old Oct 23, 2001 | 02:15 PM
cymfc3s's Avatar
I Raise Chickens
yep.
Old Oct 23, 2001 | 03:31 PM
Josepi's Avatar
Despise Enmity
Awesome, I just didn't want to go and do something retarded like fry my ecu by error checking
befarrer
Microtech
Aug 22, 2015 05:52 PM
elfking
Aug 19, 2015 09:48 PM
ncds_fc
Aug 15, 2015 10:06 AM
