Recent Dyno
Old Feb 20, 2004 | 03:17 PM
dmcrx7's Avatar
Recent Dyno
Recent Dyno!!
Mods:
Recently rebuilt motor with ceramic apex seals and lightened rotors
Majestic Turbo upgrade to S4 Turbo
3" S/S Downpipe to 3" High flow cat
GT Spec exhaust minus presilencer
SAFC running off boost signal
Greddy Profec B spec II set to 9-10psi
4X720s
New FD3S Fuel Pump
Mazdacomp Radiator
Black Magic Fan
Old Feb 22, 2004 | 07:31 AM
RETed's Avatar
Why are the lines so wavy???
-Ted
Old Feb 23, 2004 | 01:59 AM
casio's Avatar
casio isn't here.
your power at 4500rpm wouldnt pass the "vertical line test."
Old Feb 23, 2004 | 02:48 AM
TonyTurboII's Avatar
Glock Lover
Wow. Seems a bit low to me.
Old Feb 24, 2004 | 06:22 AM
gsracer's Avatar
EIT
Is the majestic turbo upgrade the standard to4e - 46 trim with the slight clip on the exhuast wheel?
Overall peak number seem's a little lower than I'd
expect, but it looks like there is a lot of area under the
curve. You're also on the stock IC...which especially on
an upgraded turbo can hinder peformance as the air
becomes overheated. I think you have a lot of potential
power to extract....
Just curious what is your ignition timing set to? Stock?
Old Mar 7, 2004 | 08:13 PM
dmcrx7's Avatar
ReTED,
Mostly because the graphs are scaled differently than usual. The total scale on A/F is spread out over most of a page instead of just at the bottom.
casio, what is the vertical line test?
gsracer,
Yes, that is the correct upgrade.
Ignition is retarded 3-4 deg via the CAS. Also, I run 5 gals 100 octane to 10 gals 93 octane when running over 8 psi. - This is only done on a road course anyway.
I am looking for a high flow top mount. I have the IC insulated with some high tech injection mold insulation that keeps it pretty cool, but I need better flow.
The profec B comes on to 6 psi immediately, then holds to about 3000, then slowly builds to 9 psi by 4500.
Current settings are 0 gain, 8.2 start boost, 35% duty cycle. The slow build is intentional. I can set the start boost to 8.5 and get faster response with a 0.5 to 1 psi overshoot, but I want the boost to come on progressively to make use of it on the road course.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
RXeckless
Sep 12, 2015 04:52 AM
Clacor
Sep 11, 2015 08:36 PM
AXA
Sep 5, 2015 10:06 AM
