Questions before undertaking Turbo rebuild...
Old Feb 17, 2004 | 09:25 AM
areXseven's Avatar
il Cosa Nostra e vivo!!
From: Dove le cose sono fatte il vecchio moda il senso
I'll be installing a Turbo Rebuild Kit on my Primary Turbo this week-end. Are there any tips you guys can offer on taking Turbo(S) off the engine and taking Turbo apart so that the rebuild goes smooth. It's the first time I undertake such a task. All comments and advise is much appreciated. Thanks. -Jimmy
Old Feb 17, 2004 | 06:21 PM
kaching's Avatar
I think the most important thing is to mark everything to be sure that it goes back in properly. It's easy to get the housings and snails out of rotation. I learned this the hard way.
Also, mark the compressor wheel so that it will remain balanced when you put them back together.
Be careful with the carbon seals when installing. They are pretty easy to crack.
Gook Luck!
Old Feb 17, 2004 | 06:23 PM
kaching's Avatar
Also,
Just curious why you are doing one turbo. After going through all of the work to get them off and clean them up, it would probably be a good idea to just do both.
Old Feb 17, 2004 | 10:17 PM
areXseven's Avatar
Originally posted by kaching
Also,
I just want to make sure I can do it, and do it right. If I don't run into any major problems with the Primary rebuild, I'll more than likely order another kit for the Secondary Turbo. But, as I mentioned previously, the secondary turbo is a boosting *****!! Thanks for your reply and help. -Jimmy
Old Feb 17, 2004 | 10:47 PM
911GT2's Avatar
The Power of 1.3
Take pics and do a nice write up for the rest of us newbs who've never done turbo rebuilds
Old Feb 18, 2004 | 07:13 AM
areXseven's Avatar
Will do!. Thanks.
Old Feb 18, 2004 | 07:39 AM
RX7UP's Avatar
BOYCOTT EXXON MOBIL!!!
Don't forget to prime the turbos just before you put them back, (oiling them./put oil in lines,etc.). Also do a search, some here have already successfully and unsuccessfully completed this meticulous task.....
PS. Good luck.... You're gonna need it....
Old Feb 23, 2004 | 09:23 AM
areXseven's Avatar
Just got my Turbo Rebuild Kit delivered. I'll post a few photos of the components in the next hour..
Old Feb 23, 2004 | 10:01 AM
areXseven's Avatar
Photo of the front of the box........
Old Feb 23, 2004 | 10:03 AM
areXseven's Avatar
Photo of the back of the box....
Old Feb 23, 2004 | 10:05 AM
areXseven's Avatar
Photo of the sheet of Instructions provided with the Kit....
Old Feb 23, 2004 | 10:07 AM
areXseven's Avatar
Photo of the components as they were shipped/packaged...
Old Feb 23, 2004 | 10:10 AM
areXseven's Avatar
And finally, a photo illustrating the individual components...
Old Feb 23, 2004 | 10:13 AM
areXseven's Avatar
...Hopefully, photos of me kicking the **** out of the Turbo because of my inability to perform the rebuild, will not surface on the Forum. Wish me luck.
Old Feb 23, 2004 | 10:26 AM
Enconsiderate's Avatar
I am so smrt.
GOOD LUCK!!!!!!!
I will be doing the sam in about a week. Please do a nice write up along w/ plenty of pics. I appreciate your help.
Also are you using a glass beed blaster?
Old Feb 23, 2004 | 10:32 AM
areXseven's Avatar
Originally posted by Enconsiderate
GOOD LUCK!!!!!!!
No bead blaster. I'll have to see how bad the internal housing is. If I can't get it cleaned with over-the-counter cleaning chemicals and a little elbow grease, I'll take it to a shop and have it blasted. Good luck to you as well. Check for PMs in case I need to compare the rebuild process with you. Thanks. -Jimmy
Old Feb 23, 2004 | 10:53 AM
TwinTurbo93's Avatar
0-rotor-0-turbo-0-fd
What I learned whem I rebuilded my turbos was that the stock Thrust Bearing (the big C shapped brass one) has 2 holes (bigger) and the Turbo City's has 3 smaller diametter holes, which is much more likely to clogg up compare to stock ones.
I took my turbo out twice after the rebuilt, and ened up using the stock ones for that reason.
The thrust bearing has no efect realy on the performance of the turbo exept for alowing oil through for lube purposes, and I think the stock one is just perfect, most importantly the Thrust Bearing can never go bad anyway b/c there is no physical contact with the shaft and cannot be worn out.
Also do both of them at the same time, is just a pita, nothing to worry, make sure you mark stuff up precisely and you'll be OK and make sure to clean and keep things extra clean.
Good luck.
Old Feb 23, 2004 | 11:05 AM
areXseven's Avatar
...The thrust bearing has no efect realy on the performance of the turbo exept for alowing oil through for lube purposes, and I think the stock one is just perfect, most importantly the Thrust Bearing can never go bad anyway b/c there is no physical contact with the shaft and cannot be worn out.
Good luck.
Thanks for the heads-up. I'll take it into consideration.
Old Feb 23, 2004 | 11:12 AM
RX7Wishing's Avatar
BOOOYAHHHH!
AGREED!!!
Old Feb 23, 2004 | 11:19 AM
areXseven's Avatar
Oh believe me!.,.. I'm gonna document the S#!t out of this rebuild (with video). So posting digital photos won't be a problem. Thanks.
Old Feb 23, 2004 | 12:56 PM
jfxp's Avatar
Rotor Nut
woohoo!, i've been looking for pics of a rebuild, thanks arexseven
Old Feb 23, 2004 | 01:55 PM
I am so smrt.
I sure wouldn't mind a copy of that video! Perhaps you can zip it and send it via AIM????
Speedworks's Avatar
Well..w here do I know those parts from???
Just a question, i also did a turbo rebuild with such a kit and it's fairly easy onces the turbo is open.
Just one thing... You'll need to have the turbo balanced before putting it back. due to the wear of the propellor shaft there may be some intolerance with the new bearings, still causing oil to leak and so on...
Be sure to do that. it'll cost you more than the rebuld kit, that's for sure
Old Feb 23, 2004 | 02:36 PM
poss's Avatar
Slower Traffic Keep Right
Good luck.
While the thrust bearing doesn't contact the shaft, it does keep the turbine shaft located axially. That's what a thrust bearing/plate does. There should be no reason for those holes to plug just because they are smaller either.
Old Feb 23, 2004 | 02:54 PM
There is a small crome ring (I can't remeber the name) that is placed into the thrust bearing and that ring actualy has contact with the shaft which is replacet with new one on turbo city reb. kit.
I just think is a common sense that such little holes are way easyer to clogg up than the biger ones, don't you think?
It happen to me twice and I just don't wish to anyone have the same problem as I did, if is possible to avoid!
