Clutch cyl line help
Old Feb 14, 2004 | 12:20 PM
etherhuffer's Avatar
I just got a full clutch cyl and slave from Mazdatrix. The SS line is male/female, but the slave cyl is a female thread. I have have not dug under the hood yet. Is there a fitting or line on the slave that the female fitting goes on? This is an 83.
Old Feb 14, 2004 | 12:39 PM
81Rex6port13b's Avatar
I Push My Car Real Fast!
on the slave it should be a male end. and you screw the female end of the line on to it.
Old Feb 14, 2004 | 12:40 PM
mazdaverx713b's Avatar
Have RX-7, will restore
yes, it hooks to the steel line from the clutch master cyl. it'll run along the firewall. there's a clip that holds it down. make sure you remove that before you try to take the line out.
Old Feb 16, 2004 | 09:46 PM
Thanks guys, I did a brain fade and just looked at the parts without popping the hood. The hard line was the missing link. Worked like a charm.
Old Feb 16, 2004 | 10:13 PM
glad to hear it worked out! hope everything goes well!
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Inspector71
Aug 26, 2015 12:06 PM
