Sponsored by: CARiD
why do the turbo's do this
Old Feb 11, 2004 | 08:23 PM
1SxyRXy's Avatar
my fc broke
well i noticed that the PSI doesnt stay solid all the way to redline, it bleeds off. why is this?
Old Feb 12, 2004 | 07:11 AM
shaq's Avatar
what does it go down too? does it go down by alot?you may have a boost leak ?
mine fd does this, i notice alot is based on how cold or warm the outside temp. is, colder it is better it boosts, i think when i get a fmic maybe it will sort the problem out.
mine only drops a little tho second turbo peaks to 0.8 then holds 0.7 (or under sometimes)
ShaQ
Old Feb 12, 2004 | 01:26 PM
RETed's Avatar
It's a mechanical system - it's not closed loop.
-Ted
Old Feb 13, 2004 | 12:41 AM
1SxyRXy's Avatar
my fc broke
well it doesnt go down alot. maybe by 1 or 2psi by 7grand i guess it just depends on the weather
Old Feb 13, 2004 | 01:10 AM
wwilliam54's Avatar
it WILL run
the amount of air used by the engine goes up with load
the turbo is sized to keep up with load up to the med/high rpms range, so at high rpms, it just cant keep up all the way
thats why a bigger turbo at the same PSI will make more power
edit:cold air is denser and easier to keep the engine fed with
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
