Sponsored by: CARiD
Peripheral Ports?
Old Feb 11, 2004 | 03:42 PM
Peripheral Ports?
how is the Peripheral Port diffrent that a bridge or street port? what is the process in doing it, also what kind of performance gains does it produce?
what does the finished product look like? pictures would be great
Old Feb 11, 2004 | 03:54 PM
i think that periphrial ports are just the location of the port. when you get it a block ported they shave off metal around the port. this changes the timing of the engine and also allows the power to be increased.
Old Feb 11, 2004 | 05:15 PM
BigTone's Avatar
Periphrial ports are race only ports. In a periphrial ported engine, the normal side intake ports are filled in and a massive intake port is created on the rotor housing much like the exhaust port. Periphrial ports have massive power in the upper RPM band, dont idle very well below 3000rpm and can easily spin to 10k and above.
he is quick link is a small picture
ehh link didnt work.
Old Feb 11, 2004 | 05:16 PM
Digi7ech's Avatar
I break Diff mounts
P Ports are insane.
There is no longer a side intake. They drill a hole in the side of the housing and it is a direct entrance.
Racing beats housings were crazy when I stopped by there at Sevenstock.
The water jacket is compromised and they fill it in with a putty stuff to seal around it. That's one of the main reasons why the P-ports don't last long.
I forget HP amounts but it's big. Also Very non streetable. Like a 1.5k idle at best.
here is RB's housings. The silver intake on the top left is it.
Old Feb 11, 2004 | 05:22 PM
holy **** that is one huge intake! I can tell why they aren't streetable...!
Old Feb 12, 2004 | 12:50 PM
Joshshift's Avatar
they dont fill it in with putty, its called devcon.
Old Feb 12, 2004 | 05:11 PM
peejay's Avatar
Old [Sch|F]ool
I'm sitting out on this one. I'll just fire up the popcorn popper and sit back and watch. Who wants extra butter?
Old Feb 12, 2004 | 09:45 PM
j9fd3s's Avatar
Community Builder
me!
Old Feb 13, 2004 | 01:13 AM
wwilliam54's Avatar
it WILL run
they arent streetable
but you can drive em on the street
Old Feb 13, 2004 | 03:28 AM
PDF's Avatar
PDF
I have 4 pp's on the road, number 5 will be joining them very soon. The oldest is a 12a pp I built 2 1/2 years ago and is a daily driver. It still starts and runs as well as it did when I built it. Flat 13's in street trim.
Old Feb 13, 2004 | 12:27 PM
peejay's Avatar
Old [Sch|F]ool
SHHH!!! Don't tell anyone you're driving a PP on the street! Remember they idle at like 5000rpm and don't start making power until like 14,000...
Old Feb 13, 2004 | 10:41 PM
PDF's Avatar
PDF
...and they last for a whole 6 months before needing a rebuild
Old Feb 14, 2004 | 09:22 AM
Tugboat's Avatar
I've always wondered about the reason for the side intake ports. I don't know about the effect on seals, but the port size and timing are the factors determining the powerband. Model (O.S.) wankels don't use side porting and they're docile.
Thanks
Old Feb 14, 2004 | 09:52 PM
peejay's Avatar
Old [Sch|F]ool
Same reason Mazda went to side exhaust ports: Less port timing for similar port volume/opening area.
Downside (for intake) being that during the opening phase of the intake port, it be quite difficult for the airflow to make basically a 180 degree turn followed by a 70-90 degree turn downwards. Bridge ports help this greatly, and peripheral ports solve it completely.
Old Feb 15, 2004 | 08:51 PM
Tugboat's Avatar
OK, that sounds logical. Why not use both for max area?
Thanks
Old Feb 17, 2004 | 06:06 PM
peejay's Avatar
Old [Sch|F]ool
It's not really "max area", a race peripheral port barely has more port area than a stocker. However, the port placement is more avantageous for VE, at the expense of having far too much overlap to idle well or cruise well.
NSU used small peripheral ports on their production engines. Their solution to the idle/cruise problem was twofold: first, they used an automatic transmission (semiautomatic, actually) so the torque converter would take up the low-end slack, and second, they used a smallish (10A-sized) engine in a heavyish (FC-sized) car for the Ro80. So the engine is under fairly heavy load.
Still, that little engine made a peak of ~120hp at only 5500rpm.
josef 91 vert
14
Sep 17, 2015 09:22 PM
