Installing Midpipe ??
Old Feb 9, 2004 | 03:23 PM
Rene Barfred's Avatar
Red Dragon
Smile Installing Midpipe ??
Hi guys !
Some questions to answer PLEASE !! I have a midpipe and are considering installing it to see the difference, but what should I look out for ? what can the results be if not done proberly, I mean what more should I consider upgrade if I will try it ? Right now I have a Petitt downpipe, Racing beat catback exhaust, Petitt cold air induction system, TKT lightned flywheel, HKS SQV Blow off valve, Power FC ECU, the car runs smooth and have a perfect rich air/fuel mixture, boost is 11-12-14 PSI when pushed i 3. gear pulling good and strong. Will it be best to put in a restrictor plate when installing midpipe ? or what will you recommend, or can I just swap it on and see the air/fuel mixture and that it is not leaning out and if, add fuel ? could i get boostcreep or would it be ok not to do anything ?
Renč
Old Feb 11, 2004 | 06:18 AM
cruiser's Avatar
I think we already answered that to you in the European part of the forum. You have seberal options with midpipe:
1) restrictor plate
2) ported wastegate
3) are lucky and its fine
4) you get boost creep and detonate - blow that 13BREW
And I wouldnt be running 14psi on stock injectors if I were you...
Old Feb 11, 2004 | 08:16 AM
Red Dragon
Thank's Cruiser !
OK, seems one can do several things. How do I make a restrictor plate ? can you buy such one ? what exactly is it and what does it do ? maybe I can find some informations somewhere that you know of ? thank's once again. Take care !
Renč
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
Enzo1944
Sep 6, 2015 08:57 AM
