carb cleaner trick for vacuum leaks
Old Feb 9, 2004 | 03:18 PM
rotarypower83's Avatar
what should idle do when i spray around carb go up or down?
Old Feb 9, 2004 | 03:26 PM
slashdawg00110's Avatar
RTFFAQ
up and smoother.
Another interesting trick for finding vac leaks.
https://www.rx7club.com/showthread.p...t=carb+cleaner
Old Feb 9, 2004 | 03:33 PM
vipernicus42's Avatar
Rotoholic Moderookie
Depends what you're spraying!
Carb cleaner will make idle drop if you're spraying it around the carb.
Jon
Old Feb 9, 2004 | 03:48 PM
RTFFAQ
I would swear that idle rises when I hit the leaks. In any case, what you're listening for is a change in idle quality when you spray the area with a leak.
t-von
Sep 10, 2015 01:56 PM
gabescanlon
Sep 5, 2015 12:04 AM
rotor_veux
Sep 3, 2015 07:10 PM
