12A powered Go-Kart.
Old Feb 1, 2004 | 10:06 PM
180sx-x's Avatar
Zoom-ing Goon.
i know this has been done many times before, but i dont care, its fun as hell. any way, i have most the things i need, now a problem arised as i was planning it out...what am i gonna do for idle? im not using a tranny, imma have the motor directly connected to the rear end,so, i was thinkin of something to use for idle, and i came across a torque converter...can i use this for the idle, and then when i push the gas, i'll accelerate(how u spell it?)...i just need this and i can start building...thank guys.
Old Feb 2, 2004 | 12:30 AM
rxtasy3's Avatar
use the bellhousing from a rib case tranny, clutch setup and the input shaft from a junk tranny. frabricate a case to support the shaft and bolt it to the bellhousing. all this attached to a sprocket will drive the rear wheels. work just like a regular go cart engine but with manual clutch.
Old Feb 2, 2004 | 12:58 AM
Shamrock.James's Avatar
why just a 12a???
http://www.meditech.ch/exoticthermoengineering/ete10.html
even better if not a bit over the top....
http://www.meditech.ch/exoticthermoe...ing/ete08.html
Old Feb 2, 2004 | 03:55 AM
rototiller1's Avatar
Inspector, Falcon Jet
travercely mount the engine, and use a snowmobile clutch system
Old Feb 2, 2004 | 10:56 AM
MazdaRx7Racer4Life's Avatar
I AM A THIEF!! READ THE FEEDBACK SECTION!
Originally posted by Shamrock.James
why just a 12a???
170mph in 2.7 seconds? Thats Bike killer! Skyline Killer! Supra Killer! A Go Kart! lol
Old Feb 3, 2004 | 12:59 PM
pinkfloyd's Avatar
not sure anymore
holy **** thats fast
Old Feb 5, 2004 | 11:56 AM
Re-Speed.com's Avatar
I've got the bits to stack a single rotor 12A that would be perfect if you are interested.
-billy
Old Feb 6, 2004 | 02:02 PM
if it was single rotors, wouldn't it be 6a?
Old Feb 7, 2004 | 07:06 PM
I guess really it would be a .6A
I posted it on ebay anyways.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMESSE%3AIT
-billy
Old Feb 14, 2004 | 03:08 PM
Jesuscookies's Avatar
I can haz rotary?
Dude...Save yourself the time an effort. Drop a 13B turbo in it. You'll make a good news headline
Old Feb 15, 2004 | 09:55 AM
rotarypower101's Avatar
sdrawkcab
I smell a Darwin award.
Old Feb 15, 2004 | 02:04 PM
Aaron Cake's Avatar
Engine, Not Motor
It's funny...I'm building a 12A motorcycle (NOT a trike) and am doing EXACTLY this.
Years ago I also designed an eccentric for a single rotor 12A, as well a the necessary modifications to install two gears on a rotor for crazy high redlines...Never built it though.
Old Feb 15, 2004 | 08:45 PM
Windsor, Ont
Holy CRAP, I'm building a turbojet powerd Go-Cart with a Truck Turbo, I only expect like 50LB of thrust, not 750 like that!!! WOW!
Old Feb 16, 2004 | 03:58 AM
Jeff20B's Avatar
Lapping = Fapping
Are you goning to use propane as fuel for the turbojet?
The1Sun
Mar 18, 2018 11:08 PM
alphawolff
Nov 17, 2015 05:57 PM
rx7brandon
Aug 16, 2015 10:55 AM
