out?
Old Jan 21, 2004 | 06:56 PM
83gslRX-7's Avatar
out?
ok this may sound dumb and very :noob: like but im trying to tune the lumpieness of my idle and i keep reading about turning the mixture screw "out" but what way ... counter clockwise or clockwise... is out? i tried searching but all i get is how many turns out, from 3 to 3 and a half turns. thanks
Old Jan 21, 2004 | 06:59 PM
kettlman's Avatar
THE ONE. THE ONLY!
counterr clockwise. best bet is to turn it clockwise all the way in, not tight though just until it wants to stop. and count how many turns it takes just to know were it was. then work it out.when you get 2 to 2 1/2 start turning a 1/4 at a time to fine tune it.
Old Jan 21, 2004 | 07:42 PM
slashdawg00110's Avatar
RTFFAQ
yes, CCL. And be very careful when you run it all the way in. Too hard and you've mashed the tip of the adjuster thingy. Then you'll never get a good idle and you'll have to buy a new one. So be gentle.
Old Jan 21, 2004 | 07:44 PM
83gslRX-7's Avatar
thanks what about the idle screw how many tunrs out should that be?
Old Jan 22, 2004 | 01:19 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
The idle screw and the mixture screw interact with each other. You will probably need to readjust them several times, taking careful note of their effects, before you get it right. I'd start with the idle screw first.
Good luck!
Old Jan 22, 2004 | 06:35 AM
Steve Shulz's Avatar
Idle screw to get desired RPM, turn in mixture screw untill the car sputters and wants to die, back of 1/4 turn, should be good. May have to repeat till you get it just right!
Old Jan 22, 2004 | 07:45 AM
vipernicus42's Avatar
Rotoholic Moderookie
Righty = Tighty
Lefty = Loosey
Loose = Out
Therefore left Just some tips on how to remember.
Jon
Old Jan 22, 2004 | 09:52 AM
83gslRX-7's Avatar
thanks guys
Old Jan 22, 2004 | 03:06 PM
grantmac's Avatar
Just a question, is turning the screw out leaning the mix or richening?
Grant
Old Jan 22, 2004 | 03:40 PM
Richer.
