Sponsored by: CARiD
Bigger Engine
Old Jan 14, 2004 | 02:31 PM
Radien Black's Avatar
Bigger Engine
I realize that the rotary is sectional heres my question I have two 13b's is there any way to build them together to have a quadruple lobe engine i understand alot of fabrication would need to be done .
Old Jan 14, 2004 | 02:38 PM
Kai's Avatar
Kai
Rotorphile.
That would be a psuedo R26B, and it has been done. You need a custom multi-peice eccentic shaft and manifolds to say the least.
Old Jan 14, 2004 | 02:42 PM
whoa i didnt even know about something like this... thats some crazy stuff...
Old Jan 14, 2004 | 02:50 PM
Digi7ech's Avatar
I break Diff mounts
4 rotor or maybe 3 rotor. You'll probably need the 3 rotor intermediate plates.
Some people have estimated over 25k to build an engine like this.
I have only seen one 4 rotor and it was at Sevenstock 6 in a red FD.
Sorry to say this but if you have to ask then don't.
Also to help answer another Q.
A 3 rotor will got you 10k at the minimun to put into a FC.
Old Jan 14, 2004 | 02:57 PM
j200pruf's Avatar
RIP Icemark
Grannys speed shop did a motor like this, you should contact them, just search for "grannys speed shop" in google.
Old Jan 14, 2004 | 04:14 PM
andrew lohaus's Avatar
i remeber someone posting a vid of a white fd from japan with a 4-rotor it sounded badass. more power to you if you want to take it on as a project. just dont count on getting it in a car anytim soon and i hope you have engineering level design and fabrication skills. good luck tho it would be realy cool to see the approach to making one.
Old Jan 14, 2004 | 05:10 PM
chairchild's Avatar
50mpg - oooooh yeah!
Have the two engines totally seperate, but join them together via a seperate shaft between the front plate, and the rear plate
It'll be huge, but you'll have your 4-rotor engine
Old Jan 14, 2004 | 06:39 PM
Jeff20B's Avatar
Lapping = Fapping
A school bus or a boat would be good candidates for two 13Bs hooked together.
Old Jan 15, 2004 | 05:54 PM
chairchild's Avatar
Or if you were to use a custom frame and shell to put them in, you could always use two engines, two gearbox's (with linked shafts) and have split diferentials at the rear - one engine powering each rear wheel
well, its different!!!
Old Jan 15, 2004 | 06:03 PM
ScrapFC's Avatar
Emerald Triangle for life
I think the 4-rotor FD you're talking about is from Scoot. I've still got the vid and it sounds like some mutant bike engine. The other one can be found here Granny's and includes an excellent tech writeup on how they did it/how to do your own.
Also, Blue TII recently posted a couple of threads on an Australian 4-rotor PP FC. Talk about badass!
Remember that a 4-rotor will be LONG and HEAVY! You won't fit that in any RX7 engine bay without EXTENSIVE modifications.
Old Jan 17, 2004 | 02:09 AM
Jeff20B's Avatar
Lapping = Fapping
Let's figure out an easy way to build a FWD rotary. Put one 13B up front, and one 13B in the rear hatch of a small FWD car. Link both shifters, clutch cylinders/cables and throttle cables together. Viola! AWD 4 rotor powered econo box.
Old Jan 17, 2004 | 08:43 PM
chairchild's Avatar
or get the entire drivetrain from a 4WD car, and lob a rotary engine on it
Remove the radiator, and cut a hole into the bonnet slightly smaller then the radiator. Fit the radiator into the bonnet. That'll give you plenty of room
Old Jan 17, 2004 | 10:35 PM
Newbie
dam... a 3 rotary engine's good enough for me. but if u have the money, then by all means go for it.
Old Jan 18, 2004 | 05:40 PM
chairchild's Avatar
I'd love to make a 4-rotor like Granny's. It'd look sweet in the back of my trike!!!
Old Jan 20, 2004 | 12:54 AM
Sponge Bob Square Pants's Avatar
Scoot 4-Rotor FD (pictures, specs, videos)
https://www.rx7club.com/showthread.p...hreadid=261572
Here's another site that's around, but pretty slow progress and not much to see.
www.4rotor.com
Jim Downing has been doing 4 rotors for years I think.
Jeff Bruce (new zealand, or is it australia?) makes custom eccentric shafts. He makes the shafts for many top drag racers. A 2 or 3pc shaft is another option.
That's all the info I got.
Old Mar 19, 2004 | 11:45 AM
sorry all have been away for a while thanks for the help I have a friend at a machine shop that is going to help me but i still need to figure out how to fit this beast into my car
any ideas on that one
(p.s. like the four wheel drive idea!)
Old Mar 19, 2004 | 02:00 PM
Jeff20B's Avatar
Lapping = Fapping
The AWD idea? Me too.
Old Mar 25, 2004 | 09:03 AM
totallimmortal's Avatar
Is that thing Turbo?
good luck, I hope your machine shop guy gan make a good strong e shaft for it that should be the biggest problem
immanuel__7
89
Sep 5, 2015 10:23 AM
josef 91 vert
23
Sep 3, 2015 11:20 AM
