DYNO Chart -- 14lb and Stock IC
Old Jan 12, 2004 | 09:06 PM
neoamd's Avatar
LS Powered
Full non-seq
All the bolt ons
No cats
PFC
http://209.51.159.6/car/dynochart.jpg
Winter is great. FMIC will be here in a month or so!
Old Jan 12, 2004 | 09:08 PM
Fd3BOOST's Avatar
Recovering Milkaholic
way to go Josh.
Old Jan 12, 2004 | 09:10 PM
teamstealth's Avatar
Ozone Depleter
what were your fuel mods, inj duties, and air temps if you dont mind posting them
CowsniperRX7's Avatar
Rear Admiral
impressive! does "all the bolt ons" include any fuel mods?
Old Jan 12, 2004 | 09:11 PM
oakridgerx7's Avatar
any fuel mods, stock motor?
Old Jan 12, 2004 | 09:16 PM
SPOautos's Avatar
Hey, where did my $$$ go?
It looks like your getting about a 2psi boost spike at 3700rpms. Since you already running 14psi that means you might be running lean right there.
Do you have a graph of your a/f?
STEPHEN
Old Jan 12, 2004 | 09:23 PM
neoamd's Avatar
LS Powered
Mods:
Street ported motor
3' Downpipe (Pettit)
3' Midpipe (Custom)
3.75' Catback (Apexi GT Spec)
Greddy Pulleys
Pettit Cold Air Intake
Full Non-Seq Twins (Stock twins still)
Removed AWS, EGR, etc etc..
Apexi Power FC Standalone with Commander
Walbro 255lph Fuel Pump
1300cc secondaries and 550cc primaries
Old Jan 12, 2004 | 09:30 PM
neoamd's Avatar
LS Powered
Inj duty at W/O throttle is 76.4% til redline.
Fuel: 1300 seconds and 550 primaries. Both cleaned and flow test by RX
Intake temp dont go over 43 cel unless I stop and let it sit for a while. usually around 38! Winter is the best!
Old Jan 12, 2004 | 09:51 PM
Ozone Depleter
nice! I was 75% sure the stock fuel system could only handle 12psi...just makin sure
Old Jan 12, 2004 | 10:26 PM
SPOautos's Avatar
The stock fuel system can handle 14psi with stock engine and twins but thats pushing it.....its basically maxed out at that point
STEPHEN
Old Jan 13, 2004 | 01:01 PM
TwinTurbo93's Avatar
0-rotor-0-turbo-0-fd
It's actualy 14.7, that's when the stock fuel system is maxed out.
Old Jan 13, 2004 | 01:21 PM
RX7UP's Avatar
BOYCOTT EXXON MOBIL!!!
Originally posted by neoamd
Mods:
Street ported motor
3' Midpipe (Custom)
Greddy Pulleys
Got 3mm apex seals? If you get a single turbo and Pettits Stock mount large intercooler, you'll get 400 hp easy...
Old Jan 13, 2004 | 04:29 PM
neoamd's Avatar
LS Powered
Nope, stock 2 peice 2mm.
Dont the big dif in bigger seals.. Im getting a FMIC and sooner or later a nice size single (GT40R-T66)
Josh
Old Jan 16, 2004 | 07:32 AM
RX7UP's Avatar
Dont the big dif in bigger seals.. Josh
What? & Why?
Old Jan 16, 2004 | 11:46 AM
Wargasm's Avatar
Weird Cat Man
added to http://www.catenet.net/dyno.php
Brian
Old Jan 16, 2004 | 02:45 PM
neoamd's Avatar
LS Powered
What? & Why?
i dont find the cost worth it.. ErnieT ran a 10.73 on a bone *** stock reman. 3mm arent needed
No need to argue.. just my opinion!
Old Jan 16, 2004 | 02:46 PM
neoamd's Avatar
LS Powered
Brian
Sweet! Thanks Brian!
Old Jan 17, 2004 | 01:08 AM
RX7UP's Avatar
No arguement here... How many pounds of boost is ErnieT pushing? Why do some people sudjest 3mm seals for unlimited boost?... Honestly, Is your opinion just based on cost?.... If you had an unlimited amount of money would you get 3mm seals?...Truthfully!!! Whats your time in the 1/4 at 366 rwhp?.....
PS. I am not the one to argue...
Old Jan 17, 2004 | 10:05 AM
neoamd's Avatar
LS Powered
I think he was pushing 26lbs. Not 100% sure though.
No, not based on cost. The stock seal will take upwards of 30lb or so.
With these cars RX7UP the key to EVERYTHING is tuning! If I have alot of money id just get a half brideged 20b and a y2k , then Id go supra highway hinting..
I havent ran my car at the track yet. Im going someitme in feb. Shouldnt be too bad.. I have Kunhos that SUCK! So I should have a kinda high et and a fat trap
Josh
Old Jan 17, 2004 | 01:23 PM
RX7UP's Avatar
Neoamd:
I hope you are not joshin me.... LOL....Good enough .... Keep me posted
Dwayne
Old Jan 17, 2004 | 02:50 PM
neoamd's Avatar
LS Powered
Neoamd:
Dwayne
Ill scan the slip
It'll be the first time Ive ever driven a car on the track sooo.. lol
Old May 5, 2004 | 10:55 AM
Rx-7Addict's Avatar
Rotary Powered
Please let me know what 1/4 mile times you run. Ive got similar mods (minus the fuel injectors) but I'm at 13psi with 90% max injector dutys on the stock secondaries. I plan on upgrading the injectors when I go FMIC.
Old May 5, 2004 | 02:10 PM
Bucrx7's Avatar
ErnieT ran 20psi for that 10sec run.
Old May 5, 2004 | 02:16 PM
matty's Avatar
Mods:
Street ported motor
3' Midpipe (Custom)
Greddy Pulleys
no ignition amp?
Old May 5, 2004 | 02:18 PM
matty's Avatar
STEPHEN
u think?
howcome my car was in high 90s at 12. psi with an 11.2 afr!?
