high idle problem
Old Jan 8, 2004 | 05:35 PM
akrx7's Avatar
high idle problem
The idle on my son's 87 non turbo won't go under 1500 rpm. The air screw on top of the engine is completely closed. The tsp was adjusted according to the book and the idle loped, by backing out the adjusting screw more the idle leveled out but we can't get it under 1500 rpm. Any ideas put there??
Old Jan 8, 2004 | 05:41 PM
I have the same problem. I also have replaced the BAC
Old Jan 8, 2004 | 05:44 PM
BlackIceGuitar's Avatar
clean your BAC. Test it. Check for a leak anywhere. or a pinched/pulled throttle cable.
Old Jan 8, 2004 | 05:55 PM
J-Rat's Avatar
Alcohol Fueled!
I assume you let the car warm up before you tested your TPS?
Old Jan 8, 2004 | 05:58 PM
akrx7's Avatar
the engine was fully warmed up. the throttle cable is not pinched, will try cleaning the BAC. Thanks
Old Jan 8, 2004 | 07:47 PM
Turbonut's Avatar
As stated before, eliminate the BAC to see if that's the problem. Either cut a gasket and place it between the BAC and manifold without the center cutout, or simply plug the end of the BAC so no air will enter. Then give it a try. If idle still high, not the BAC.
Old Jan 9, 2004 | 07:59 PM
croffeyc's Avatar
RLRR LRLL
'89 NA
I plugged the input of the BAC and the car won't even start. Also, when the car is running and I unplug the input hose from the air funnel, the car stalls right out.
Does this mean that the BAC is bad?
Thanks.
Old Jan 10, 2004 | 08:34 AM
croffeyc's Avatar
RLRR LRLL
Bump
Old Jan 24, 2004 | 01:47 PM
dorifc3s's Avatar
pics?
13
Jan 9, 2018 11:19 AM
Microtech
30
Apr 23, 2016 06:37 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
