How Can I Tell If My Cats Are Clogged
Old Jan 8, 2004 | 01:02 PM
white84GS's Avatar
Question How Can I Tell If My Cats Are Clogged
Hey guys.....I was just wondering how to tell if my cats are clogged cause i have no power...my friend's 1990 Eagle Talon with no turbo has way more kick than my 7 (i have a higher top end though). This shouldnt be? Any ideas?
Old Jan 8, 2004 | 01:36 PM
exodus82's Avatar
Yeah it should, those Talons can beat 7s. Take it to a muffler shop itll be about $25.
Old Jan 8, 2004 | 02:06 PM
Rotofire's Avatar
Yea, I'm working on it...
take off your cat and take a broom handle poke through your cats until all the crap falls out may be illeagal but no more pesky cats! or you could get a cat replacement pipe from Racing Beat www.racingbeat.com it should help
851stgen12a's Avatar
Off riding sportbikes!
HAHAHAHA Getting beat by a n/a Talon!!!
Just joking. My brother has a 90 talon and my very mildely moded 7 will spank it in almost any aspect other than a top speed run where he pulls away from 110mph.
How quickley does the motor rev from an idle?? if the cats are cloged it should rev pretty slow. Also typicaly your exhaust manfold will be glowing if the cats are clogged.
Old Jan 8, 2004 | 03:47 PM
white84GS's Avatar
It doesnt rev to fast from an idle (not as much as id like) So my Minfold will glow because it gets too hot?...how long do i have to run it to see it get hot.....is there a way i could just take my cat apart and clean it?
Old Jan 8, 2004 | 04:31 PM
slashdawg00110's Avatar
RTFFAQ
No, you can't clean it. Once the catalyst is used, it's used. You can't reverse the catalytic chemical reaction. More information here: http://auto.howstuffworks.com/catalytic-converter.htm
Run the car for a while. Then look underneath at the cat itself. That's what will glow red. Don't park in a grass field when you're doing this unless you want to see a lot more red. YMMV.
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
