which optima
Old Jan 8, 2004 | 03:44 AM
fc3seeker's Avatar
T2 Noob.
which optima
My battery is going dead... I was thinking of getting an optima yellow top.... there are some many models, which one should i get for a T2
http://www.tna-sports.com/index.cfm?...6903&pageid=30
http://batteriesareus.com/shop/index...4cf9bc7b5c7520
any1 know of a cheaper place to get one ?
Old Jan 8, 2004 | 04:29 AM
I wish I was driving!
Re: which optima
Why yellow? They're deep cycle batteries.
Old Jan 8, 2004 | 05:01 AM
fc3seeker's Avatar
T2 Noob.
whats your suggestion then
Old Jan 8, 2004 | 05:21 AM
Standard redtop, it'll last longer.
Deep cycle batteries are for those planning to regurly discharge 80% of the battery. Fortunately, you have a alternator to prevent this.
Old Jan 8, 2004 | 06:01 AM
silverrotor's Avatar
Coincidently, I just won this Optima Yellow Top on ebay. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2449921543 I need this In order to relocate Inside. Good deal?
Old Jan 8, 2004 | 06:07 AM
Yep.
Are you planning on staying NHRA legal?
Old Jan 8, 2004 | 02:56 PM
88ROTARY's Avatar
get a red top, its for starting, i have a red top in my car.
Old Jan 8, 2004 | 03:02 PM
88ROTARY's Avatar
buying a battery off of ebay wasn't that smart. not trying to rag you but you will have no warranty unless you have a hook-up at a parts store that will work with you. I bout my red top from advance auto parts, thats with a 3yr free replacement, it was worth spending the extra.(150ish)(new) yours 91.00 + shipping( estimated 30.00) used good luck
Old Jan 8, 2004 | 03:09 PM
J-Rat's Avatar
Alcohol Fueled!
I agree with Sean, the yellow top is overkill. The only reason I run one, is because its the only one they make in the size that I needed.
Jarrett
Old Jan 8, 2004 | 03:10 PM
Aaron Cake's Avatar
Engine, Not Motor
I've posted before on the yellow vs. red difference, but scathcart basically summarized it...
There's no need to get a yellow top unless you regularily discharge your battery. Deep cycle batteries have thicker plates to allow this, but that also means they are more expensive and have a completely different charging profile. A car alternator basically charges the battery to around 14V then cuts off. A deep cycle needs a constant current charge up to about 14V, then a constant voltage charge to about 14.9 to obtain proper life. Thus, an automotive alternator cannot provide the ideal charging curve....Does it really matter? No, not really because battery life in a car is short anyway....But it does mean that the extra money you spend for the yellow top is essentially wasted.
That said, I have a yellow top for my car because I have a nasty habit of deep discharging my batteries...
Old Jan 8, 2004 | 04:07 PM
fc3seeker's Avatar
T2 Noob.
so 34 red top good enough ?
Old Jan 8, 2004 | 04:11 PM
Aaron Cake's Avatar
Engine, Not Motor
Yes.
Old Jan 8, 2004 | 06:49 PM
Originally posted by scathcart
Yep.
That would mean an additional 10lbs and a kill switch? I may decide to do this. My FC Is heading Into this direction.
Originally posted by 88ROTARY
buying a battery off of ebay wasn't that smart. not trying to rag you but you will have no warranty unless you have a hook-up at a parts store that will work with you...
A give and take I guess. But you are right for the most part. I'll be able to figure something out down here - should anything go wrong.
Old Jan 8, 2004 | 06:53 PM
Jarrett
I don't believe you relocated It. I remember you saying this In another thread. Is yours the same part # as mine?
Originally posted by Aaron Cake
...That said, I have a yellow top for my car because I have a nasty habit of deep discharging my batteries...
haha. Rhetoricisim at It's best, eh Aaron?
Old Jan 8, 2004 | 07:08 PM
J-Rat's Avatar
Alcohol Fueled!
I didnt relocate my Batt, I run the yellow top half size one. I dont know the part number off the top of my head. I have to run that battery cause I am running a K2RD radiator, and I DO NOT want to relocate.
Old Jan 8, 2004 | 07:54 PM
Hey, Aaron, I know that the plates are thicker in a deep cycle battery, but I thought the main difference with Deep cycle batteries was the fact that they have solid plates (lots of thin plates) as opposed to the lead "sponge" plates (more surface area) of starting batteries.
This would be why you can't deep cycle a starting battery... the fine lead "sponge" is consumed and falls to the bottom of the battery.
How those that don't know, a battery is just an electrolytic chemical reaction between sulphuric acid and lead.
Old Jan 8, 2004 | 09:32 PM
The Battery Is brand new 88 ROTARY, but whatever...
Aaron, how does the Optima Yellow Top differentiate from the Battery we were looking at?
RCCAZ 1
Aug 11, 2015 07:05 PM
damian
Feb 28, 2004 12:51 AM
Andrew Harper
Jul 24, 2003 08:11 AM
